Question about Husqvarna Vacuums
Sewing machine Viking emerald 183 lost manual in move. how to move needle position from side to side within foot ? Any on line manuals? TU ---gina
2 Suggested Answers
  • 736 Answers
SOURCE: The presser foot is stuck in the down position.
if you open the left end of the machine .. look inside above the needle and to the back .. you will see a pivot bolt that has either come loose, broken off or fallen out .. replacing that bolt should fix the problem ..
Posted on Jun 07, 2010
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
Jul 03, 2014 | SewShop.com Singer Model 900 Futura...
7467S sewing machine beeps four time and won't let me sew
Hi! Probably too late to help the original asker, but I have this same machine and was having the exact same problem. 4 beep error message, but mine would not sew at all. Found this question through a google search, but no answer. But I figured it out! I had left the buttonhole lever down!! (Facepalm) I hope this is helpful to future googlers with a similar problem.
Feb 05, 2014 | Singer 7467S Confidence Stylist Electric...
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
Hi, I have a silly question. How on earth do I thread my Brother Xr-65 sewing machine?!! I have misplaced the users manual during my recent move. It seems to take thread a little differently than my...
The XR-65 and the XR-65T are the same except that the T indicates the sewing machine was sold with the Quilting Table and some accessories for quilting.
To thread the sewing machine, first lift the presser foot and use the handwheel to raise the needle to its highest position. The thread take up lever should be at its highest point. Place the spool of thread on the horizontal pin secured with the appropriate cap. Make sure that the thread comes off the spool from the bottom front, (Also check that the catch (for holding the thread when not in use) on the spool is at the back of the pin.) Then bring the thread to the thread guide at the back of the machine then down past the reverse lever and back up the the thread take up lever. Wrap the thread around the take up lever so that it slides into the slot and then goes through the hole in the take up lever from right to left. Bring the thread down again and place it behind the guide above the needle. Then thread the needle from front to back.
Brother has the manual available for download: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf . See page 31 (43 of the PDF) for the pictures of the upper thread path.
I hope this helps.
Jul 29, 2011 | Vacuums
Hello, I have a Viking Topaz sewing machine, the top thread is visible on the underside of fabric, indicating a tension problem. I have cleaned the machine, turned it off and back on, rethread it numberous...
Thread, Tension, Needle.
Make sure your needle matches your application. example: heavy denim needs a heavy needle (90-100) instead of the "universal" needle that usually comes with a machine.
Also make sure that when you thread your machine that you have the pressure foot in the up position. Many machines release the tension discs in this position allowing for proper threading. Also make sure there is no fluff, lint, etc., in your tension areas.
Mar 11, 2011 | Vacuums
Sewing machine needle not moving up and down
Well there are many things to check (causes) -
Upper thread has run out. Presser foot is up.
Bobbin winder shaft was left in winding position.
Buttonhole lever was not lowered when machine was placed in buttonhole mode.
Anyway you may try the steps below to correct this (Solution) -
Replace empty spool and thread machine.
Lower presser foot.
Move bobbin winder shaft back fully to left.
Lower buttonhole lever.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
The presser foot is stuck in the down position on my sewing machine. The lever goes up and down but the foot will not move. Help! I have an old Kenmore 22 sewing machine. Probably got it around 1990. The...
Jun 05, 2010 | Vacuums
Vacuums Logo
51 people viewed this question
Top Husqvarna Vacuums Experts
JoeVacs
Are you a Husqvarna Vacuum Expert? Answer questions, earn points and help others
