Question about GE PSS25SGNBS Side by Side Refrigerator
On my GE refrigerator is not getting cold at all in the refrig nor the freezer. When I open the door the light is on and the fan is running. Is there an enteral fuise?
  • GE Master
  • 1,606 Answers
The compressor relay is bad on the main control board . Unplug the refrig and pull the refrig out and remove the 8X10 small panel on the back . You will see a blue plug with 3 larger (120v) wires going to it . Remove this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . (this is on the plug NOT the board ) . Using a short piece of insulated wire , with about 1/4" stripped off both ends , insert 1 end into wire1 and the other into wire3 . Plug the refrig back in . This will start the compressor to verify the main control board is bad . Pt # WR55X10942 .
Posted on Aug 20, 2010
  • 3 more comments
  • dan970 Aug 20, 2010
    You the Man aasc,
    Then I followed your instructions, the compressor started right up, so I'm ordering a new control board. Thank you for saving me a coulpe of hundred bucks. I love the internet and guys like yourself helping others.
    Thanks Dan from Colorado
    You the Man aasc,
    You the Man aasc,
    Then I followed your instructions, the compressor started right up, so I'm ordering a new control board. I love the internet and guys like yourself helping others.
    You the Man aasc,
    You the Man aasc,
    Thanks Dan
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Have ge gt mdl# gts22jbpbrww. the freezer is cold but the refrig is not getting cold. I took apart the cover showing me the freezer fan and it is not working could this be why the refrig is not getting...
Yes, if the fan is not forcing the cold air from the freezer section to the refrigerator section, then it will be warmer than it should be. Also check to make sure that the cooling tubes aren't blocked with frost/ice. If you put a hair dryer to the cooling tube openings you should feel the air flow on the other side.
Sep 06, 2011 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
My GE refrigerator GDS18LBPWW with freezer on bottom does not cool in the refrig. section. Yesterday, I pd $239 to have the Evaporator Fan motor replaced. The freezer is fine and back down to 26, but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Dec 29, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
REFRIG WILL NOT GET ANYTHING COLD
make sure there is no frost buildup behinde the freezer back panal and the ducts to the frig are clear. Leaving the door open will make a lot of frost and diminish the cooling capacity.
Eric
Jun 24, 2009 | Amana ARB190ZCS Bottom Freezer...
Open Questions:
GE PSS25SGNBS Side by Side Refrigerator Logo
160 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
