Question about Magic Chef CGR3725 Gas Kitchen Range
I have a magic chef gas stove model number cgr3730adh. The oven is not preheating and broiler is not working the the ignitor has an orange glow.
  • betsy_g_thom Aug 19, 2010
    When I turned the oven to preheat to 350 after 1.5 hrs. it was still not preheated but the oven was warm. the broiler decided to come on. does that change your opinion?
    i have a magic chef gas stove model number cgr3730adh. The oven is not preheating and broiler is not working the the ignitor has an orange glow.
    I set the oven to preheat at 350 degrees after an hour and half it was just warm
  • 905 Answers
Hello Betsy,
There can be a few causes of this condition.
Foremost, it is good that the igniter is glowing, it shows that there is some life in the oven control.
If you never smell gas, then the gas valve is defective, or is not receiving voltage from the control to turn it on.
If you do smell gas, then the flame sense electrode may be out of position (which should at least momentarily allow burner to light), or the flow of gas is restricted and not enough gas is reaching the burner.
You are probably looking at replacing the oven gas valve. Checking it with a multimeter for 1) operating voltage when it should be on and 2) for coil resistances (both coils should be the same and within specs) when voltage and wires are removed from it.
Posted on Aug 19, 2010
    Genius:
  • 1,478 Answers
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Take care.
Posted on Aug 20, 2010
Magic Cheff gas kitchen range oven and broiler will not turn on. Get orange glow from igniter but gas will not turn on. Today we tried the oven and it worked. It was tuned on at 350 for 20 minutes before...
Hello thats great that you get an orange glow out of the ignitor but it still could be faulty.You would need a multimeter that can measure amperes or an ampere meter an ignitor is supposed to draw between 3 - 3.3 amps any less then this would constitute a weak ignitor and you would have to replace the ignitor. My personal opinion is that yours is most likely drawing around 2 amps which is way to low and that is why it is taking so long for the flame to ignite. If after you perform the ampere test you find that your ignitor is functioning at the specified amounts then message me back for further diagnosis. Thanks I await your reply
Rick
Aug 15, 2011 | Magic Chef Kitchen Ranges
My gas oven (Frigidaire Gallery) is not preheating or coming up to temperature. The broiler and stove top burners work fine.
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
Jul 18, 2011 | Frigidaire Ovens
My Magic Chef model 9112XUB wall oven will not light. It has power and gas but will not ignite.What can I do to fix it myself?
If this model has electronic ignition, you can open up the broiler door , turn on the oven, and look to the rear of the broiler...there should be a sort of glow plug getting reddish/orange. If not, the oven won't light and you will need to obtain an ignitor for the oven. these are available through appliance parts distributors such as Bell Parts Suppy. If it is a standing pilot model, then first check to see if the pilot is lit...if it's not lit try lighting...if it won't stay lit, then the thermocouple is probably bad and will need to be replaced
Dec 19, 2010 | Magic Chef 31100 Gas Kitchen Range
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
Replaced bad thermostat on Magic Chef model 9112xpb. Ignitor now glows orange but oven still won't start. Does gas valve on bottom of oven need to point up or sideways to start?
Gas shut off valve handles are perpendicular to the gasline when closed and parallel when opened. If you are referring to the appliance regulator behind the stove, the lever should face up or out, as opposed to sideways. This particular lever only shuts gas down to the oven and not the stovetop.
Let us know if you need more assistance.
May 16, 2010 | Magic Chef Ovens
Magic Chef gas stove... oven does not work... It uses the ceramic unit to ignite which glows but gas does not come... Both the broiler and top burners work
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 05, 2010 | Kitchen Ranges
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Magic Chef freestanding gas oven/stove - oven won't ignite and heat, stove works fine.
most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Mar 17, 2008 | Kitchen Ranges
Magic Chef CGR3725 Gas Kitchen Range Logo
263 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
