Question about Honeywell ER150B Air Conditioner
Who should i call to come look at our a/c ? its very hot , system says its on but no cool air is coming out?
  • 107 Answers
I would ask around to friends and family first to see if they have had a good experience with someone. Usually the one that advertises the most is not the honest company..
Posted on Aug 20, 2010
My 2005 Cadillac escalade is running hot change thermostat and flushed out radiator still running hot when released cap it was a lot of pressure coming from coolant
the 3 easiest things/ tests to do would be these,
1 remove cap from cooling system and run until at operating temp, check for bubbles in cooling system, if bubbles then there is a head gasket failure ( exhaust gases in the system )
2 check cooling fans to see if working, most have a high and low, for under a light or heavy load.
3 could have a water pump that has a failed impeller and not circulating coolant
Sep 03, 2015 | Cadillac Cars & Trucks
02 ford explorer 4.0 overheating and suddenly blowing cold air, then hot again while engine runs cool but not long
Most likely you have air trapped in your engine, particularly in the heater loop. You need to properly bleed the air out of your radiator cooling system. The hot and cold blasts of air coming from first hot water followed by air.
Read up on how to bleed air out of your radiator system. Some systems are very difficult to bleed.
If after doing a good bleed of the radiator system the problem returns, you may have a bad head gasket or other leak in your cooling system which is injecting air into the cooling system (radiator/water cooling system).
Aug 12, 2014 | 2002 Ford Explorer
2003cadillac cts running hot change thermostra
You may have replaced the right thing,but make sure there is no air in the cooling system,if there is it will run hot,with the air conditioner off,make sure the cooling fans come on,and go off on there own,if they do not,then there is air in the system or the coolant tempurature sensor is bad,most likely.The cooling fan relays could cause this also ,or the cooling fan,or fans have gone out,and need to be replaced.
May 12, 2013 | Cars & Trucks
Cooling system seems to be vapor locked
If your car gets hot it means that you have a cooling system issue. Have you replaced thermostat?
Make your Jeep looking as good as new by replacing your Jeep Tops.
Mar 07, 2013 | Cars & Trucks
Car is running hot and I put a new thermostat in and water bump
make sure the radiator cooling fans are coming on. GM has also had major problems with the lower intake gaskets leaking on the V-6 engines. sometimes when refilling the cooling systems air lock can occur. run the engine until it warms up and then turn off and let it cool down, if coolant level goes down repeat this process two or three times. other causes could be clogged radiator, or worse case scenario blown head gaskets. also i have on occasion got bad thermostats from the parts store. the upper radiator hose will get very hot when the thermostat opens. run the engine and hold the upper hose and when the t-stat opens the hose will get hot. then when the cooling fan comes on hot air will rush from from the fans. if the fans come on and the air is cool then there is a circulation problem. t-stat, clogged radiator, low coolant, head gaskets. good luck.
Jul 14, 2012 | 2000 Chevrolet Malibu
Cool air coming from the vents in the front but hot air coming from the back. What do I do to stop the hot air so that the room will cool down?
The hot air is a product of the cooling.... if you stop that then the unit will not cool!!!
You need to buy an exhaust kit to vent the hot air outside so that it will cool the room.
Otherwise it is just what is called a spot cooler or in other words you are cool if you sit in front of it, but it actually will make the overall room temp. hotter!!
heatman101
Jul 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Fiat seicento 2000 reg keeps overheating after going 5 or so miles, light comes on then grumbling and water from expansion tank. had new radiator switch put on, took fan off and tested-works ok- but not...
This may be a puzzle...
The seicento (I drive the same car) likes to create problems in the heater section of the cooling system. The small pipes to it (behind the carburator) may be blocked or the entire heater may simply be dirty. Flushing the system with a water hose may help. Usually this problem starts slowly and goes away if you re-start the engine and then excellerate a few times. Check if your heater blows hot air - if yes, and if he keeps blowing hot air (does not cool down and get cold) ther is no blockage. If you have a blockage, your heater will only blow hot for a little while and then comes normal cool air - if this is the case, you have a blockage right in your heating system which runs your cooling system hot and the cap of your cooling tank will start leaking. This is a comon problem on older Seicentos....
Other general problems can also be the case, like defective thermostat, fan motor does not come on (check fuse and relais first).
In some cases, ther might be some air trapped in the cooling system and doing the above will also cure it. At last, check if your water pump is working.
Regards
Herbert
Sep 24, 2010 | 2006 Fiat Pininfarina
My sisters olds alero is overheating. What is the
Take a heater hose off and start it up, it should push it out, a lot, like 10psi pressure. Is the cooling system clean? not rusty?Does the heater blow hot air when the engine is hot, if so thats good. when the cooling fan comes on, is the air coming through the radiator hot...it should be. if not, the radiator may be stopped up. if the top and lower hoses are hot, but the air coming through the radiator is cool, the radiator is plugged, and will need to be taken apart and cleaned by a radiator shop, or better yet, replaced.
Oct 15, 2009 | 2001 Oldsmobile Alero
My bmw 325i as heating problem,we replace the water pump,termostate,and radiator,but its still running hot ,any suggestion
my 1990 325i bmw is running hot
it seems to have a lot of air in the cooling system
i replaced the head gasket, water pump and thermostat
how do i get the air out of the system
Sep 16, 2009 | 2001 BMW 325
Honeywell ER150B Air Conditioner Logo
29 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
