Setting the IP address on Konica 7030 multi-function copier
Hello. I am in a small office setting and have inherited a Konica 7030 and have only been using the copy feature. We want to now network it as a printer/scanner but cannot set the IP address. Any suggestions?
  • Anonymous Jul 03, 2008
    How do you change the IP manually? Is there an on screen section for it somewhere.
If you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
Posted on May 03, 2008
How to change ip address to konica minolta dialta 470 or connect to printer from computer
work out ip address of computer like for example usually 10.0.0.2 or 198.168.0.2 submask 255.255.255.0 then go to printer and select settings - network settings - ip address and put in xx.xx.xx.253
xx.xx.xx is the network address like 10.0.0 or 198.168.0 and the same subnet mask as computer is using. .
computer run
dos prompt
type in
ipconfig
press enter key
Jan 23, 2017 | Konica Minolta Office Equipment & Supplies
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
I have a konica bizhub c351, I have changed my network here at the office. This IP address is 192.168.15.50 and now I need to change it to 192.168.0.50. Can you help me?
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Nov 25, 2009 | Konica Minolta bizhub C351 All-In-One...
No Access to Minolta DI251F
Are you sure it asks for a username? Most Konica Minolta machines only need a admin password to make changes to the settings. If so, try 'sysadm' as the password.
Mar 24, 2009 | Minolta DI251F Laser Printer
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Mar 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Copier won't print - IP address was switched?
i need a service manual of minolta di251 digital cpier
Dec 11, 2007 | Konica Minolta DiALTA Di200 Copier
929 people viewed this question
k24674
jasbo
jasbo
