Question about General Wire MR Mini-Rooter Basic Unit
How do i install a replacement cable on a mini rooter auger
How do I change or find out my password to connect to the internet?
You can access the administration of your rooter with a browser on your computer: often it is http://192.168.2.1 but it change according to the company. The user is "admin" with no password if you haven't changed it.
You can also reset your rooter with a trombone in a hole at the rear. it will be reset without any password.
If you have a rooter provided by a company like Bell or AT&T, ask them to reset the password.
Write your password on a paper !!!
Jul 01, 2014 | Apple iPad Mini
Cecilware MT Mini granita machine
you have a magnetic auger drive which means it's sealed between the motor and the inner auger. if there is liquid actively dripping on the inside from the back, the plastic under the magnet on the back of the inner auger has worn through. remove the bowl, the outer auger, and the inner auger (pull hard- it's a big magnet). the tubular black plastic that the auger was around may have scratches and holes in it. press the plastic all around the outside. if it gives, you have a hole. unfortunately, in order to get that replaced you need to sever the refrigeration line, which means big bucks. sorry, but you've been had.
Apr 16, 2012 | Cecilware MT 2 UL FrigoGranita Slush...
Recently, one of my toilets won't flush properly. It is my guess that during a recent visit, a friend threw an apparently disposable object in the toilet. Since then, it won't completely flush unless I use...
May need to remove the toilet and see if the object is in the loop of the toilet drain inside the toilet-if so you can manually reach inside sometimes to remove object-if it has passed and is in your line below your floor now that the toilet is off you can use the auger or a garden hose with a thin sprayer set to high force that down into drain if you cannot see the object and see if you can push it thru to your septic tank or sub station tank depending what you have-if that dont work --hello roto rooter-
Oct 02, 2017 | Home
Not sure how to reroute auger cable on craftsman snowblower
I assume the cable to the auger was removed and needs to be re-installed.
There should be a clamp that the cable ran thru, then attaches to the auger
control. Find this clamp on your snowblower, and route it thru this clamp
then attach it to your auger control.
Feb 25, 2011 | Garden
Installed auger belt on my 421 snowblower and the auger turns all the time.
Sounds like the auger belt is too tight. What belt did you use? Toro 37-9080? If you used the right belt, there is an adjustment on the cable going to the pulley that pulls the belt. Follow the cable to where it goes into the side of the machine. There should be an adjuster. Loosen the adjuster so that there is enough free play so the auger does not turn when the handle is not pulled.
Feb 14, 2011 | Toro Garden
The spring on my auger clutch cable broke. Where does this spring connect too? I ordered a new cable and spring but I can't locate where the spring connects too. I have a model 317-611D000 snowblower
my auger cable is not working the auger so i adjusted it and it was to tight and the plastic holder that holds the cables poped off and broke,now the cable i adjust it and nothing happens,cable is all hooked up and seems ok but it will not work right,but the auger spins with out the cable,wondering if it needs a new auger cable
Dec 26, 2010 | Mtd Genuine 9460897 Snow Blower Auger...
I need help: i cant get the my rooter to send out a wireless sign
might be the powre is not comming ............
chech out the adapter,,,,,,,,,,,,,,,,,
Jun 26, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connecting to rooter
Make sure the cables are firmly attached, and locked into place in both ethernet ports, both on the router and the Xbox. I get this issue sometimes and it's annoying... i know ^^
Jul 14, 2008 | Microsoft Xbox 360 Console
How can i get my wireless rooter to work
Wireless cards come in many different forms: external USB devices, internal PCI Cards desktops, external PC (PCMCIA) Cards for laptops, and internal mini PCI cards for laptops.
What type of computer are wanting to make work with your wireless router? Laptop or PC?
Feb 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
General Wire MR Mini-Rooter Basic Unit Logo
644 people viewed this question
Top General Wire Electrical Supplies Experts
Steve Mason
robert
Franco Pinto
Are you a General Wire Electrical Supply Expert? Answer questions, earn points and help others
