Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
I purchased a Cruzer USB 2.0 Flash Drive 4gb and when I inserted it into port for first time, I think it installed some kind of driver first and I was able to use it find. How ever when I when to my DVD RW Drive (E:) to retrieve data from a CD disc, it would not bring up any files on the disc. Did the Flash Driver driver disable the DVD drive? Thanks Wayne
  • SanDisk Master
  • 5,481 Answers
Unless your computer or flash drive did something weird, the USB drive had nothing to do with the DVD drive issue. (There have been drives sold with malware do to issues at the manufacturer/distributor. These affect the registry so you might try rolling back to a previous configuration in the System Restore after you do a malware/antivirus scan either in Safe Mode or from a LiveCD (preferred). The advantage of the LiveCD is that the malware really can't protect itself since the boot sequence is fully independent of the usual OS.)
Most likely though your optical drive failed for some other reason. Check the device manager for any driver issues (Control Panel > Hardware or Computer > right click on the optical drive and choose Properties and then the Hardware Tab followed by clicking on the optical drive. Then click Properties and the Drivers tab.). If you can, try a disc cleaner to clean the lens. Also check that the cables are fully seated (both to the motherboard and the optical drive). Consider trying a new data cable.
With today's prices, it usually isn't worth repairing an optical drive. However the most common issue is the lens tracking and lens transport system.
I hope this helps.
I hope this helps.
Posted on Aug 19, 2010
How to savedata on it
Darius,
Remove the cover from the USB head.
2. Insert the drive into USB port on the computer.
3. Start My Computer and locate an additional drive listed in it.
4. This is the Flash drive.
5. Use it as any other drive to copy/paste any data to it from any other drive.
Cheers.
Jan 12, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I am a student in school, and I am not to computer savvy on Flash drive.. It did not come with any instructions on how to use it. It is a Cruzer USB 2.0 Flash Drive (4GB) Can you help me with step-by-step...
  • Boot up your computer and find an open USB port. These are small, rectangular ports typically on the sides or backs of laptop computers, or on the fronts or backs of desktop towers.
  • Plug your flash drive into the USB port. The drive will slide in only if it is turned in the right direction, so if you have trouble inserting it, turn it over.
  • Make sure your computer sees the flash drive. It should launch a menu, letting you know that it has found a new storage device. You can choose an option from the menu or close the menu if you don't need to immediately access the flash drive.
  • Install the flash drive's driver if your computer doesn't recognize the flash drive. The flash drive's packaging should include the manufacturer's website address. Open your Internet browser, go to that address, and download the flash drive's driver from the site. Install the driver on your computer. After that, your computer should be able to recognize your drive.
  • Jan 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    Instructions on how to operate a sandisk cruzer us 2.0 flash drive. what is supposed to happen when i insert the drive, should any on screen instructions inform me what i am transferring to the drive.
    Your system will automatically recognize your sandisk and will automatically install the drivers for it (this will show on the time taskbar located at the lower right side of the screen). After successfully loading the drivers you can now access your usb drive by going to My computer and should have the drive letter after your cd/dvd drive.
    Sep 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    I am not able to access the drive on my lap top, can you email me the driver.
    USB flash drive doesnt require any driver to be installed. Please try this Flash driver on a different USB port or in a different computer to see if it the port or the computer or the flash drive which has issues
    Aug 23, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    I purchased 4GB Cruzer ubs 2.0 flash drive. before I open the package, will there be instructions inside?
    OK, don't worry.. It will all work Out-of-the-box, The instruction are simple. Unpack, Pluc in to a USB port, software will detect and install necessary drivers... then ya good to go. Simply treat it as another drive... Cut, copy, Paste.. If you want you can install any software from the manufacturer, that may have come with the unit.
    Jan 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    Unknown device
    Plug it through different USB ports, even a USB Hub, or on a different computer. Sometimes rebooting solves the problem. I suspect it is a USB problem, especially on laptops with a small number of USB ports.
    I have given mine up as dead several times, but it always comes back up gain.
    Hope it helps.
    Sep 16, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    Plz Help Me
    I'm not an expert with PCs, but I have a windows 98 Operating system and have been able to use all sorts of flash drives. Everytime I buy a new one, I just plug it into the USB port and in a short time it recognizes NEW HARDWARE and loads the driver. I've used LEXAR 2GB,SANDISK 4GB, VERBATIM 2GB, and recently a ATIVA 4GB
    Apr 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    Sandisk 4GB cruzer micro usb flash hard drive
    try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
    Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    U3 2GB Cruzer Micro wont work on my vista laptop.
    Hi there, I found the solution (for all 4GB flash drives).
    Initially when I plugged in my PQi 4GB flash drive with Windows Vista,
    there was an error message involving " Can not find the drivers needed ... "
    Simply download & install "Windows Vista Service Pack 1"
    it is about 444 MB in size.
    The whole process might take about 2 hours to install,
    but it is worth it.
    These are the links where you can find your download:
    http://technet.microsoft.com/en-us/windowsvista/bb738089.aspx
    OR
    http://www.microsoft.com/downloads/details.aspx?familyid=090DEAF6-2EAA-4AAA-8B3B-2E199DB4A97D&displaylang=en
    It works perfectly... good luck now...
    Sep 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
    57 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Carlos Calvo
    Level 1 Expert
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
