Question about kawasaki Cycling
Trying to replace fr & rear shifter cables can not get hand shifter apart to put in new cable
  • 843 Answers
You shouldn't have to disassemble the shift levers. Remove the cable from the cable clamp at the business end. Push the cable a bit toward the shift lever. The little barrel end of the cable at the lever end should raise itself out of the lever, then you can just pull the whole cable out. Make sure your replacement cable and cable sleeve are about the same length as the originals. The new cable can be longer because you can cut it off later, but the cable sleeve should be pretty close to the same length as the original - maybe 1/4 inch longer would be ok.
Posted on Aug 19, 2010
Bicycle rear derailleur slips back to high gear.
It is likely that Phil has an old school Shimano Eagle rear derailleur.
I recently had a very similar issue with a Suntour friction shifter and derailleur. I tried replacing the shift cable and housing with no luck. Then I was told to replace the chain. Made no difference.
Then I took a closer look at my bike's shifter. I took my old one apart and the gear teeth that were supposed to keep the shifter from moving were worn down.
New shifter took care of it for me.
Oct 22, 2012 | Cycling
Mercruiser lower unite in nutural lock how to fix
Unhook the cable connection from the shift lever at the lower.Try to shift by hand with a cresent wrench,(small,and don't force).Sounds like you've a keeper dropped off in the lower.It's easy enough to pull the lower apart,but better have someone there that knows the unit or buy a repair manual for that lower.
Aug 28, 2012 | Cars & Trucks
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
Shimano STX (combo brake and shifter) rear shifter does nothing up or down. Shifters move but do not engage the derailleur. The cable is tight and obviously not broken. Is the shifter broken or can...
You can't have end-to-end intact cable movement and NOT move the derailleur unless it is NOT tight to begin with. Look closer.
You need to figure out at which end the problem lies.
You can elevate the rear wheel (or hang the bike by the tip of the seat on a low branch) and pedaling it forward with your hand you can grab the bare exposed cable somewhere in its routing (usually along the down tube) and pull sideways on it (away from the bike) to see if the derailleur moves as expected when the cable REALLY moves. Then you can decide if the shifter is or is not controlling the cable.
Everything is replaceable as required.
Adjustments: http://www.parktool.com/blog/repair-help/categories/derailleur-systems
or use a search engine "how to...." for videos.
Jul 09, 2011 | Shimano Cycling
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
I have an older Huffy, with grip shifters. The shifter (left hand) is almost impossible to shift the chain from the small sprocket to the middle or largest sprocket. The deraileur seams to be moving freely...
First, try to isolate the trouble like you have... obviously the derailieur is moviong freely. Next, I would disconnect the shifter cable from the derailieur (make sure to mark previous position of cable) Next, shift the left hand grip to see if the grip moves freely, you've already replaced the cable, soooooo, disassemble the grip and grease or replace the grip shift unit...hope this helps
Jul 13, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Slipping gears on bicycle
Make sure the rear wheel axle is snugged up against he dropouts in the frame and that the wheel is centered in the brakes. Also, check the seating of the shifter cable at each end, but most likely at the rear shifter, to make sure the jacket is inside the ferrule.
Of course, it is impossible to get a sense for how well maintained the bike is. Perhaps the shifting problem's appearance is not related to the wheel removal and may be something else like bad cables or cable housing. The cable should slide easily in the housing. Shift the bike to its lowest (easiest) gears in front and in back. Then, without moving the crank, manually tug on the rear shifter cable from the rear and push it in. Resistance is bad. Sometimes a bit of lube inside the housing will buy you some time. Use something thin and squirt a little into the end then cycle the cable in and out to distribute it.
If you don't have a bike repair stand, find a small tree with a stout, narrow, low horizontal branch about shoulder height and hook the front of your seat on it so you can spin the cranks and test the shifting. If it's hard to downshift the rear (pulling cable into the housing) it will likely not freely shift upward because the only froce pulling the cable out is the little spring in the derailleur.
Shift to the highest (smallest) cog and sight along the axis of the it and the two rear derailleur pullies. They should all be in the same exact vertical alignment. If they're parallel but not aligned you can adjust the barrel on the cable at the derailleur. Try a small turn then shift up and down while turning the crank to get the cable and shifter to settle where the new adjustment wants to be.
If you ride regualrly it would be worthwhile to find a local bike shop (LBS) and get to know them. They can teach you some self sufficiency in exchange for a little business from you.
Apr 29, 2009 | Cycling
Replacing Attack's rear derailleur cable
Stop everything! Do not take the shifter apart! Go to the rear derailleur and look where the cable is attached. There is a bolt with an allen key head, it is an 8mm. Losen off the bolt. REFER TO PARKTOOL.COM
Apr 12, 2009 | Sram Attack 9-Speed Trigger Mountain Bike...
1995 Cadillac SlS Shift lever knob will not move, seems frozen.
Put your parking brake on. Remove console panel. Put foot on brake. Turn ignition key to on position (Do NOT start vehicle!). Locate park lock cable (Parallel to drivers right knee). Press down on that cable with left hand while attempting to move shifter with right hand. Replace that cable if shifter moves out of park.
Feb 23, 2009 | 1995 Cadillac Seville
8speed lx shifter to xt shifter
It depends.. Shifter cables are standard and the same one would work for both LX and XT shifters. If the old cable is full of grime etc, it is a good idea to run new cables - it will give you a smooth easy shift.
I am sure if you check www.shimano.com you will find the manual for your model of shifter. Replacing cables is pretty easy.
Jan 24, 2009 | Mountain Shimano Deore Bicycle...
Cycling Logo
Top kawasaki Cycling Experts
Jeff Turcotte
Jeff Turcotte
Ron Dufek
Ron Dufek
ray gallant
Are you a kawasaki Cycling Expert? Answer questions, earn points and help others
