Question about Cameras
Charging battery for a samsung digital camera L83t
I would like to get a download of users manual please.
  • 39 Answers
Here is the user's manual, drivers, picture for the Samsung L83T digital camera. http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=l83t
Posted on May 03, 2008
I have samsung l83t camera,when i turn it on,he turns of after 5 secs.what to do?
battery fault most likely, charge it or try a new one. Memory cards issues can cause this sometimes so remove it and try, again.
Jan 08, 2012 | Samsung L83T Digital Camera
My camera beeps, has a flashing greenlight and has a message on screen - "Turn on and off again". Still does the same, no matter what I do.
Please remove off the battery and keep aside , press down the power and trigger to discharge off any charges present on the circuit.
After 30 minutes load back after confirming on the battery terminals and the memory card ( format if there are images present after downloading them.)
Feb 24, 2011 | Samsung L83T Digital Camera
My computer won't read my samsung l83t camera
Please install the pc suite of camera on computer and paired them
Jan 24, 2011 | Samsung L83T Digital Camera
I have camera samsung L83T it wont charge what happens is when i plug in socket green light comes on on charger then red ligth flashes a couple of timers then goes off any answers thanks
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . Just replace it and problem will be solved .
good luck .
please rate !
Apr 02, 2010 | Samsung L83T Digital Camera
How do I use the self timer on my Samsung L83T?
Press right on the multiselector (marked with a one-handed clock) to cycle through the self-timer modes.
Mar 26, 2010 | Samsung L83T Digital Camera
My camera wont switch on although i have charged up battery. the camera just beeps and switches off.
There are a couple of possibilities here:
i'm assuming that this camera uses a SD memory card. You have most likely bought yourself an SDHC card. The cards will look exactly the same, except for their name. SD cards only go up to 2GB, while SDHC's go much higher....sometimes the SDHC card will cause camera's to do this because it is not supported.
the other possibility is that you have a defective battery and it doesn't hold a charge. You could test this with a digital multi meter.
hope this helps,
Thomas
Feb 28, 2010 | Samsung L83T Digital Camera
I can't download pics from Samsung L83T to 'My Pictures' Windows 7
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Jan 23, 2010 | Samsung L83T Digital Camera
My samsung promising photographer L83T won't turn on, it's fully charged and i have replaced the battery. It worked fine after i replaced the battery but when i recharged it it now wont turn on or do...
suspect that the battery may have been incorrectly charged and may be damaged.
suspect charger is not charging the battery properly.
try any reset that that camera may have.
Nov 13, 2009 | Samsung L83T Digital Camera
Cameras Logo
74 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
