Question about Whirlpool LER5634L Electric Dryer
Drier wont start altho all electrical parts seem to be working fine
    Sergeant:
  • 227 Answers
You may want to check the door switch. Depending on age and vibration, or slamming shut too hard will damage the switch.
Posted on Jan 05, 2009
CNM Touchpad 9 frozen
Did you fully charge the product?
Dec 30, 2013 | Audio Players & Recorders
My 2004 honda odessey wont start up
Dead Battery
I would think you checked that before
coming here
Dec 14, 2012 | 2004 Honda Odyssey
Built in washer drier wont start
What brand and model? Turn off the washer/dryer breaker, wait 15 seconds, then turn on (reset) the breaker.
Jan 19, 2012 | Neff Washing Machines
My drier wont start. Power at back of switch
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it iwll help you find tha thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 06, 2010 | Crosley CDE6000 Electric Dryer
Model LDE303 worked fine once we got the right
seems like the door safety switch is stuck. open door and look for it, a little dowel, see if it is clicking on and off. to test, open door, let the drier buzz and try pushing the little switch in and out.
Jul 09, 2009 | Dryers
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
How do install an ac dryer in a 2003 Toyota Echo
Theorifice and drier need to be intsalled by a service tech. Even if you know how you need a Refrigerant EPA liscense to handle refrigerat. The system needs to be pumped down and the drier and orifice removed. Sounds like you have a restriction in your line. Sometimes orifice gets stopped up but is easily removed and cleaned. Driers to stop u[ also depends if they are flare drier or need to be welded in the line. To do the repair you need guages,torch freon silver solder,vacuum pump and know whar the presures mean on the intruments.
Jun 12, 2009 | Heating & Cooling
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Leb6200 wont completely dry clothes first time.
the problem is most likely an airflow problem. if you have a flexible duct connected to the back of the machine then replace it with a smooth rigid (not pvc) metal duct. clean inside the wall or wherever the air goes to get outside (must be smooth metal at least 4" in diameter) in the wall, without too many bends. the electrical arc you spoke of would not have an effect on the heating element unless the machine is not heating at all.
Jul 04, 2008 | Whirlpool LEB6200 Electric Dryer
Drier wont start
yes there is a thermo fuse in the dryer eather on the element houseing are on the inside back by the houseing
Mar 06, 2008 | GE DBXR463EBWW Electric Dryer
Whirlpool LER5634L Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
