Question about Motorola Mobility RAZR V3
WINDOWS XP SP2 SHUTS DOWN WHEN RECOVERING FROM HIBERNATION. ALL MEMORY IS LOST AND SYSTEM IS FROZEN. THIS ONLY HAPPENED AFTER THE SBV5121XM WAS INSTALLED
    Brigadier General:
  • 7,752 Answers
Reformat the pc and then install all os and software......but remove memory
Posted on Jun 02, 2008
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
Win xp home hibernate no longer works
Right click on an empty area of your Desktop. Select Properties. Select the Screen Saver tab. Click the Power button. Click the Hibernate tab. Select the Hibernate check box.
If you can't check the hibernate option it is because you don't have enough disk space. Delete old pictures and videos that you have already backed up to make some space.
Sep 14, 2010 | Microsoft Windows XP Home Edition SP2
Acer Aspire AS 3410, OS - WIN XP, shut down not work.
that means the drivers which you had installed is not working properly. u need to download the drivers of audio video & NIC card . check out the site. support.acer-euro.com/drivers/downloads.htm. make sure you have SP3 for XP.
Apr 12, 2010 | Acer Computers & Internet
Same as above I think
first of all never never never use hibernate only use standby. you want you hard drive to crash and loose all you info keep hibernating your laptop.
Jun 22, 2009 | ASUS Eee PC 901 XP Notebook
Windows XP will not shut down.
I don't know if you've tried this yet,but here it is just in case.
Click Start, and then click Control Panel > Performance and Maintenance>Power Options>In the Power Options Properties dialog box, on the Power Schemes tab, click the Power schemes drop-down list and select the power scheme that most closely matches how you use your computer.
adjust the System standby and System hibernates settings if you are not happy with the default selection. On the Advanced tab, you can adjust the default behavior of the power buttons on your computer. Click Apply>OK
Please rate this a fixya
May 21, 2009 | IBM IntelliStation E Pro 570 (689357U) PC...
Hibernate problem
Turn off the screen saver and then enter hibernation mode......sodeep
Mar 29, 2009 | Microsoft Windows XP Professional SP2
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Autoshutdown option in windows xp
I believe from memory that you can use Task Scheduler to do this and many other things.
Just goto the HELP section in the Start menu and type Task Scheduler
Hope it helps =)
Apr 10, 2008 | Microsoft Windows XP Professional With...
Prob in PC
Are you using an installer with SP2? check your devices under my computer if all are ok.
Sep 20, 2007 | Microsoft Windows XP Professional With...
SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
