Question about Xerox DocuColor 12 Color Copier
I need to adjust my heat it isn't hot enough how do i do that?
  • 8 Answers
Check power supply voltage
Posted on Aug 22, 2010
Dishwasher not getting hot
Is your sink getting hot water? If no then probably your hot water heater needs adjusted or heating element in it replaced.
Sep 20, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
The dishwasher is not cleaning the plates and glasses as should, leaving a lot of residue on everything
It sounds like water isn't being forced through your spray lines, which could be a result of either you trap being clogged or the sump pump not working. It could also mean that your heater element isn't heating the water hot enough for it to clean.
If it only the upper rack then it could be a blockage for the upper sprayer, but if it is throughout the machice, then it would either be the sump pump, trap or heating element as the most likely causes.
Jul 03, 2011 | Dishwashers
Lawn mower dies when it gets hot when it cools off it starts until hot again I've changed the coil and module
you should change the oil and make sure you are using a good oil. Also, make sure your fuel line isn't running next to any place where it can heat up.
Jun 16, 2011 | John Deere Garden
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
The heating is not working properly, not hot enough. I tried 3 hours, but the clothes still not dry. It is a 120V Kenmore dryer.
IF THIS IS AN ELECTRIC DRYER 110 VOLTS ISN;T RIGHT 208 VOLTS SHOULD BE MORE LIKE THE ANSWER. IT TAKES 208 VOLTS TO RUN THE HEATING ELEMENT AND 120 VOLTS FOR THE MOTOR
SOMETHING DOSN'T SOUND RIGHT THERE
Feb 06, 2011 | Kenmore Dryers
Does no heat water hot enough
Thermostat adjustment is behind front panel (behind brew basket) on the left-hand side (usually) Work it up gradually otherwise you may risk boil over.
Feb 03, 2010 | Bunn CWTF15-TC
Error "HO"
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature.
Thank You Huum
Please remember to leave a solved rating before you sign off!
Dec 20, 2008 | Dishwashers
Error code HO on frigidaire gallery series dishwasher
Sep 06, 2008 | Frigidaire Dishwashers
High efficiacy 90 furnane does not blow high heat; yet the fan motor blows but not hot heat.
If the furnace blows heat, just not hot enough, you need to have a furnace company come out and adjust the manifold gas pressure. (This is not something a homeowner can to, it takes special tools)
Jun 18, 2008 | Heating & Cooling
Xerox DocuColor 12 Color Copier Logo
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
