Pump not doing anything no power ,no noise but fuse is ok and circuit breaker
  • 139 Answers
If their is 240 volts at the contactor or the fuses is the contactor on or buzzing humming its the contactor but if the contactor is not closed could be switch off on the furnance or fuse on circuit board need more info to help is the blower on in the furnance ?
Posted on Aug 20, 2010
The hot tub pump blows the power everytime I turn it on tried changing the fuse and had a look inside but can't see anything wrong please help!
Definitely a short circuit on the pump. Check that it is not wet - it might look dry but can be wet inside. Pump motor can be stuck due to worn bearings or overheating at some time. Get a electrician to test the circuit if not found to be wet. Be careful when fiddling there and switch of the mains before touching anything even with the fuse blown/circuit breaker down.
Jun 02, 2015 | MCM Lazy Man Push-Button Spark...
Keep blowing fuse for sterio which kills water pump and ac what are possible problems ?
FUSE WAREHOUSE HUH? oK, IF FUSE REPEATEDLY BLOWS, GLASS TUBE? CORRECT? tHEN YOU HAVE A SHORT CIRCUIT OR ACIRCUIT OVERLOA.D. tHE PUMP MAY BE TAKING OUT THE STEREO BECAUSEPUMPS PULL AMPS WAY MORE THAN PRETTY MUCH ANYRHING ELSE.. The pump should have a dedicated circuit. Or remove anything piggy backing on the pump circuit and bump the fuse 5 amps. Here is a trick of the trade. Go to autozone and chk out the AUTOMATIC CIRCUIT BREAKERS. bUY ONE THAT WILL FIT WHERE THE FUSE WENT.dO NOT GET THE SAME AMPERAGE. IT WILL FLUTTER LIKE A TURN SIGNAL FLASHER. NOT DESIRED BECAUSE WHILE THE BREAKER KEEPS ON AND OFFING, yOU WILL HAVE THE TIME TO REMOVE SUSPECTED WIRES. wHEN BREAKER STOPS TRIPPING, YOU HAVE FOUND THE PROBLEM CIRCUIT. tO SLOW DOW THE TRIPPING OF THE BREAKER, GET A HIGHER AMP BREAKER. bUT! dO NOT BUMP IT UP MORE THAN 5 AMPS AT A TIME OR THE RISK OF OVERHEATING YOUR WIRING SOARS. i ALWAYS HAD SOMEONE ASSIST AND WATCH FOR PROBLEMS LIKE WIRES HEATING UP, SMOKE OR SMELL. i DON'T MEAN TO SPOOK YOU, BUT YOU ARE BYPASSING THE DESIGNATED THRESHHOLD BY USING AN ALTERNATE TYPE OF CIRCUIT BREAKER WHICH RAISES THE THESHOLD IN ORDER TO DETECT AND LOCATE YOUR PROBLEM. iF THE
BREAKER CLICKS RAPIDLY, YOU HAVE A DEAD SHORTsLOW ORWIDELY SPACED TRIPPING MEANS YOU HAVE AN OVERLOAD SITUATION(TOO MUCH DEMAND ON THAT CIRCUIT. iF YOU WANT, AFTER ALL IS SAID AND DONE, TO USE AUTO CIRCUIT BREAKERS, gET THOSE OF THE SAME AMP RATING AS THE GLASS TUBE(BUSS FUSE. tO ME, THE METAL CASED ONES ARE FLAME PROOF WHERE PLASTIC MELTS .. tHEY AREN'T CHEAP BUT WORTH A TON OF BUSS FUSES. gOOD lUCK AND BE SAFE - T tHANKS FOR USING FIX-YAED NED-
Jul 24, 2014 | Keystone 2008 Cougar 289BHS
Dead after power outage
The breaker may have failed electrically while continuing to function mechanically. It may be necessary to replace the breaker, something GE should have been able to tell you without referring vaguely to "an act of nature" which it wasn't.
Feb 26, 2014 | GE Dishwashers
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Hotub clicks and then makes buzzing noise when turned on.
does it blow a breaker? check to see what is going on by unplugging all the pumps, blowers lights and anything else plugged into the circuit board (heater too)
turn the breaker on once everything is unplugged and then proceed to turn the spa off, plug one item back in and turn the breaker back on.
Do this until you find the buzzing....
You may actually have a back relay on the circuit board causing the buzzing by not latching in when the pump or something is trying to come on.
Rod
Aug 23, 2011 | Home
Windshield washer pump is not working
not likely that fuse blew but check fuse box for wiper fuse and see if blown, when u fill fluid, turn ignition on but not running hit squirter and listen for pump noise if noise is present then hit repeatedly and look if there is any leakage dripping and trace leak, if no noise check resivor for debrie floating (posisible blockage) last thing is check for power at pump with wire probs
Jul 07, 2009 | 2007 Saturn Outlook
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
