Our vaulted living room ceiling has black smudges coming through the paint...we have used Kilz paint and repainted several times...also had vents put in the roof
Vaulted ceilings are tricky. I find it is best to leave them to the professionals, especially when mold is involved. I have heard of a few rel='nofollow' href="http://www.ottawapainters.org/en/">painting companies in Ottawa</a>, but mold removal and painting may be a whole different game.
Posted on Jun 18, 2013
  • 107 Answers
Did you happen to spray the mold with Bleach before covering up ? If mold is still in growth mode even Kilz cannot keep it from penetrating.. Usually half water and half bleach would be ok. Just vent the house well.
Posted on Aug 21, 2010
How do i choose surround sound speakers to go in my ceiling?
Go to any store that sells electronics and audio products, they will be able to guide you towards the correct speaker purchase for you needs.
Dec 01, 2016 | Audio Players & Recorders
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
How much should i charge for painting a two bedroom apt. Inteior only. walls and cealing two bath one living room kitchen and laundry room
About 50 cents a square foot would be a reasonable price for a straightforward paint job (no stairs, cathedral ceilings or furniture to move).
May 28, 2014 | Measuring Tools & Sensors
Why is our ETS heater streaking the walls and ceiling black?
Electric heaters should not give off anything to make the paint go black , paint will change colour from the heat over time . I would say make sure there is nothing behind the heaters causing this to go black .
Ask where you buy your paint they can advise on paint that will not change with the heat .
Mar 17, 2012 | Heating & Cooling
Our Rinnai gasheater is in 'n working condition but since we used it the white walls and ceilings are covered with black marks - I am worried that it could be dangerous - any advice?
Unfortunately, you failed to mention the Model Number and whether its a flue-less or Vented unit. In either case, the black streaks you see on the walls and ceilings is soot. If it's a flue-less unit, this is an indication that the unit has not received routine maintenance on a regular basis. The sooting is caused by a dirty or clogged burner or low gas pressure.
Also, burning scented candles and operating the heater at the same time, will cause soot. Not from the heater, but from the candles. All candles soot, but scented candles soot more than others. Combine them with the warm moist heat and they will soot 50 times worse. If this is the case, it's the candles sooting, not the heater. Stop burning the candles while the heater is in operation.
Is the soot dangerous? Yes, to the point that you are breathing it in, when it;s floating in the air. The sooting didn't occur over night, it has been doing it for sometime. You finally realized it, when you saw the black streaks. Stop using the heater until it is professionally serviced by and authorized Rinnai Service Technician and the walls and ceiling are cleaned.
You can either remove the soot yourself or have it professionally done. Then, you should prime paint the walls and ceiling with a sealer like Kilz, before repainting. All curtains or draperies should be washed or dry cleaned. All furniture and carpeting should be vacuumed thoroughly.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
There is a yellow film on my walls and ceiling around the firepla
Hi some paints or wall coverings will yellow with the heat form the heater repaint is the only way ask at paintshop if they anything to combat this
Oct 07, 2009 | Home Decorators Collection Charmglow...
Two fans, remotes work with one, not the other
YOU MUST TRY CHANGEING THE CHANNEL ON THE REMOT AND TRY IT THEN IF IT DOES NOT WORK YOU MUST TAKE DOWN THE FAN AND CHECK WHAT CHANNEL THE RECIEVER HAS AND MATCH IT TO THE REMOTE.
Nov 04, 2007 | Hunter Vaulted Ceiling Mount - Antique...
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
