Question about Dell Computers & Internet
It will not turn on - plugged to AC power - Dell Computers & Internet
    President:
  • 3,278 Answers
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on Aug 19, 2010
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
Error remove disc and turn power off follow the manaul
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check wheather the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately. Remove the AC adapter's AC plus from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
Jan 05, 2011 | Nintendo Wii Console
Code error 32022 what is it
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check whether the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately.
Click here to download Ninento wii repair guide
Error message error occurred. press the eject button and remove the disc. turn the power off and follow the instructions in the console manual.
http://igotwii.com/nintendo-wii-manual-error-messages-page-68-69
Jan 04, 2011 | Nintendo Wii Console
Keep getting error message,remove disc and turn power off
Remove the AC adapter's AC plug from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
I get an error. error has occured press the eject botton and remove the disk and than turn off consel . and refer to the wii manual.
Dec 21, 2010 | Nintendo Wii Console
My wii keeps saying a problem has occurred so eject the game and turn the console off and refer to the manual
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket.  Next, check whether the disc is dirty or scratched.  If it is dirty, gently wipe with a soft, damp cloth from the center to the outside.  Wait 5 - 10 minutes.  Then plug the AC adapter's AC plug back into the power socket and turn the console power on.  If the same message still appears, the Wii console may be damaged. turn the Wii console off immediately.  Remove the AC adapter's AC plug from the plug and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700
Nov 28, 2009 | Nintendo Wii Console
Notebook plugged in. cannot get the dell to turn on. its not the power suppy that i plug into wall
1. remove all ext peripherals
2. remove battery
3. plug ac adapter to wall socket power (without the laptop)
4. check if the ac adapter led stays on, if yes then connect the laptop, check if the ac adapter led turns off after connecting to laptop, if not then turn on the laptop if still no power then have replace the motherboard.
Oct 15, 2009 | Dell Precision M60 Notebook
It wont work
take it to a game store to get it buffed out
Aug 07, 2009 | Nintendo Mario Kart (Wii) for Wii
Computers & Internet Logo
43 people viewed this question
Alun Cox
