Question about Mitsubishi WS-65413 65" Rear Projection Television
What is the liquid behind the lens on a mitsubishi medallion hd 1080 series tv?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Do not remove the lens! The liquid is in a sealed area between lens and each picture tube screen.
It is called Glycol and like antifreeze, meant to cool the face of each tube.
If it leaks and gets on the circuit boards usually it is fatal for the set. If you find ANY ON THE BOARDS IN YOUR SET--DO NOT TOUCH IT AS IT WILL BE ABSORBED INTO YOUR BODY THROUGH YOUR SKIN---10 times more concentrated than antifreeze.
What is the reason you ask about the Glycol? What problem or issue do you have?
If this is helpful, rate this solution as very helpful as I do this here for free. If you have questions or need more info post a comment here and I will assist you.
SD TECH
Posted on Aug 19, 2010
I have a Mitsubishi medallion 1080 Hd tv that as I'm watching it It turns off and no matter what I do it just stays on for like five seconds than turns off agsin
This just recently happened to my Samsung DLP. It's a pretty easy fix. You need to replace the lamp. Check your manual for the particulars of that model.
Mar 02, 2015 | Mitsubishi Televison & Video
I have a mitsubishi medallion hd 1080 series t.v.
yes, for under thirty dollars you can replace the chips in the set and have it working again.
Apr 17, 2012 | Mitsubishi WS-55819 55" Rear Projection...
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
I have a 63 inch projection tv, 8 years old, that stopped turning on last week. Not sure what's wrong with it. You can hear the power turn on inside the television though the screen does not turn on. No...
LOOKING AT THE AGE OF THE TV IT MIGHT HAVE DRY JOINTS ON PCB,S SO IF U KNOW ABOUT ELECTRONICS AND GOT SOLDERING IRON RESOLDER SUSPECTED SOLDER JOINTS AND THEN TRY.
Aug 12, 2010 | Mitsubishi Televison & Video
I have a mitsubishi Medallion hd 1080 and the picture is bad, colors off plus there is a yellow section along the top o the screen. Can this be repaired
Yes,U know how to solders?Ur convergence it dead,must replaced it with a convergence kit,use what in that kit.Tries these websites for the convergence kit.Tv repair World.com,Tv repair Kits.
Nov 10, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65413 65" Rear Projection Television Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
