Question about Cell Phones
Neither of my screens work, they're just black. i can call out i just have to hope i dialed the number right because i can't see. Is this fixable?
  • 4,102 Answers
Hi not knowing the make and model makes it harder for me to tell you, but by the sounds of it the problem you are having is a common problem.
now from what your describing it sounds like the problem you are having is with the data ribbon that connects the screen to the circuit board, now as this is a very common fault this makes the part cheap to buy and cheap to fit, so if you want to get your phone working properly take it into a small phone shop not a big branded one cus they will charge you loads go to a small phone shop and tell them the phone works but you have got no display, tell them you have been told its the data ribbon thats at fault they will then give you a price and should be able to fix it whilst you wait.
hope that answers your question
let me know if you need further assistance ok
Posted on Aug 19, 2010
The right side of our screen keeps going dark, almost black. Once I tapped the side of the tv and it popped back to normal. Sometimes it goes back to normal by itself. It is black most of the time though....
Yes usually fixable unless its the panel goning bad. What if you squeze the panel where the black bar is does that effect it. If so the cabinet is probably bowed. Hope this helps.
May 25, 2011 | Sanyo Televison & Video
Can mot make long distance calls
Check with your provider, and make sure you're dialing the numbers right. On MagicJack, or instance, you don't dial a 1 before the number, just area code and number. On other systems, you have to dial a 1 proceeding the entire number. If you're dialing right, and it's still not working, you need to check with your provider. If all is good at their end, your phone may be faulty. Take it into your provider to have it checked out, or check it on another system/circuit/provider.
Good luck, and hope this helps.
Apr 02, 2011 | Computers & Internet
Hi, I fell against the screen of my 50" plasma and created a crack under the glass. the screen soon turned black and now does not work. is this fixable?
The short answer is yes, it is fixable. It won't be cheap though. The entire panel must be replaced.
The part number for this is: 6348Q-C049M with a cost of $2,417.11 with a core return refund of $750 which means that after you return the bad panel, you will be credited $750. The net cost for the part then becomes: $1667.11 plus shipping.
Hope this helps,
Dan
Feb 05, 2010 | LG 50PC3D 50 in. Plasma Television
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
Technika 7" Portable DVD player
LCD panels are generally not fixable. If it's a deep crack, and leaking pixles, its a problem. If its not, it should continue working. If it's leaking, or not working right If you have some technical skills, check eBay and see if someone is selling a used one or, even better, a replacement screen. If you can't do it yourself, hopefully you know someone who could replace it. Of course, as cheap as these are, it may be easier to trash it and get a new one.
Dec 18, 2008 | Nokia 6288 Cellular Phone
Black Line on the Screen
You are going to have to take it to a repair shop to have the LCD screen replaced because once you have a black line anywhere on your screen its not fixable. sorry. Hope this helped =)
Feb 25, 2008 | Sony PlayStation Portable (PSP) Console
Dialing on 755p
Ok theres two ways to do this, heres 1 way: press menu while you our on the phone display (the button to the right of alt) use the 5 way navigator to move to the right, scroll down to phone display options. Below the Show Dial Pad/ Show Wallpaper, you'll see where it says typing dials phone number change that to typing starts contact search. This will permanently make it liek your old treo. If you wanna dial numbers press the white button to thte left of z and start dialing the numbers.
Version 2: If you dial normally it will dial numbers, if you press th white button to the left of z then type contact name also works.
hopes this help
Masalama
Feb 08, 2008 | Palm Treo 755p Smartphone
Error message E7
Ok thsi is fixable E7 is an Automatic Document feeder or finisher problem. There should be another 2 other numbers flashing after the E7 to tell you where in these options the fault is. Hope this helps
Aug 17, 2007 | Panasonic FP-7735 Black and White Copier
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
