Hello, I have an LG 23" flat panel that will not turn on. I have a dish network remote that was working to turn tv on and off, but after a few hours it quit working. Now the tv has a red light and will not turn on or off manually or with remote. When using the remote, I had to plug and unplug the tv power to get the tv to turn on. Now nothing.
  • kforr620 Aug 19, 2010
    Thanks for the response. Is there a way for me to replace the power supply board and where do I make the purchase. This was a refurbished tv with an out of date warranty. I don't want to spend more than I paid for it to put new power supply board in it.
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Aug 19, 2010
  • Walesarumi
    Walesarumi Aug 19, 2010
    yes, its possible for you to replace the power supply board yourself. All you need to do is to remove the defective board and replace it with a new one. But make sure you take a picture of the power supply board before you disconnect the wires on it so that you can put the wires back to their appropriate places on the new board.
    Also, not the TV's store a lot of current. So you need to wait a while for the TV to cool before you touch anything on the board.
    For the power board part, visit http://www.shopjimmy.com/lg or click the "contact us" and order for the board directly.
    Take care.
How do I connect my LG TV to my dish network
Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 31, 2011 | LG 42PG20 42 in. Plasma HDTV
I am in need of the programming codes for a dish network remote control. Can you please help
Hello, my name is Becki, with DISH Network. We do not currently have the codes for your particular TV. But I have included some steps to do the Power Scan, which will scan your TV for the correct code. It can take a few minutes, but should help!
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Aug 03, 2011 | Supersonic 15 in. LCD TV
I have dish network and need the remote code from the tv to activate the dish remote to change the channels, etc. And how do i program the remote to work with the tv
Hello! My name is Becki Barned with DISH Network. To program your remote, just follow these simple steps:
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
500
795
816
Becki Barned
Apr 06, 2011 | Westinghouse 26" LCD Flat-Panel HDTV
Any idea how to get my LG tv to work Dish Network's remote? i have the 32LD450
Hello! This is Dan Busa with DISH Network try this link it should help!
Daniel Busa
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Jan 09, 2011 | LG 47LD450 47 in. TV
I have bought a brand new lg tv from sams. I suscribe to the dish network. I can program the dish remote control mto turn the lg tv on, but the remote will not adjust the volume ! The dish remote is new...
Hello there!!!!! If your remote is giving you troubles, you can try a power scan, which scans through each code for the tv until you reach the correct one. Just follow the link provided below, and begin the scan. Remember when you are done programming your remote, press the SAT button on the top left of the remote. Hope this helps!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
Dec 08, 2010 | LG 50PG20 50 in. Plasma HDTV
The tv remote does not work to turn on/off television or turn up volume. cannot adjust volume or power control with dish network remote either.
I hope that you got that tv and remote working. But if you haven't, I have some steps that can help you out. If your tv remote is not working, and you want to program your DISH remote to your tv, here are the steps:
Just follow the link I provided below, which will walk you through a power scan. The power scan scan your tv for the code that works with the remote. It sounds tedious, but it's very quick and simple! I hope that it helps!
Becki Barned
Oct 12, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a DISH Network ViP722 DTV Receiver / 350-Hours Video.... Whenever I have my brightness setting below 40 on my LG TV, my Dish DVR will no longer respond to its Dish issued remote control. If I turn...
Hello! Daniel Busa with Dish Network. That would be a case of remote interference. You'll need a model 6.3 or 6.4 remote. You can set it to a uhf frequency instead of an ir that will correct the issue.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Need remote code for dish network remote to control philips tv want dvr and tv to work off the dish remote
If you have not found the codes yet, follow the link below. The link will walk you through the steps to program the remote to the tv. They are simple steps.
Codes:
If the codes do not work, try this link for a power scan, which will scan the tv for the correct code.
Becki Barned
Aug 04, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
I have dish network and need a remote code for a LG 42LH30 where do I find
Hello!!! I do hope that you were able to find these codes, but if not, here they are, with instructions for them!!!!
You will want to follow these steps:
2. Punch in the 3-digit code
3. Press the # (pound) button below the 9
4. Try to volume and powering the tv on/off. If one or more of these functions do not work, start over from step 1, with a different code!
520
654
678
Hope this helps!!!!
Becki Barned
May 16, 2010 | LG 42LH30 42 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
