Question about Whirlpool Washing Machines
Hold to start button on model ghw9200lw is not making consistent contact. Takes about 10 minutes to get it to start. How to fix?
2 Suggested Answers
  • 4088 Answers
SOURCE: whirlpool washer door won't secure
Do you mean that the door won't lock, or that it locks, but requires an extra push and hold to make things work. If the latter, find the finger in the door area that trips the interlock switch and extend it's length slightly with hot glue or epoxy a small piece of wood or some such.
Posted on Jul 16, 2009
What causes start/pause button to work sporadically?
It sounds like the switch is getting bad, contacts in the switch no doubt have burned spots and it is hard to get a connection through burned spots. So I would say replacing the switch is in order.
Jun 21, 2014 | Maytag MDE5500AYW Electric Dryer
A button and right direction on d-pad on ds lite starting not to respond
You've probably either damaged the contacts, or the contacts have gotten dirty. You can always try blowing, but your best bet is to clean them. Follow one of the guides for taking it apart.
Jun 22, 2012 | Nintendo DS Lite Console
My dyson dc14 all floors won't stay on when I press the power button. I can hold it down and it will work, but that makes cleaning very slow.
Quick Fix...takes 4 minutes max
Remove the switch by using instructions here:
http://www.sparesaver.com/vacuum-spares/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-cable.html
(The was an additional torx screw 3 " below the one in the directions...yours may have this too...just remove)
Then...While holding the body of the switch in one hand, use your other to hold both contacts between your thumb and forefinger and gently place pressure on each contact in the opposite direction, just like screwing a nut onto a bolt. Press the switch down while applying this torque and see if it sticks. If it does just bend the contacts slightly and continue pressing the switch to ensure it holds. Reinstall switch.
I still advise buying a switch from amazon for $4.00 and replacing it but this will help you to continue to use your vacuum in the meantime without having to hold the button...
Aug 11, 2011 | Dyson DC14 Telescope Reach All Floors...
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Whirlpool washer door won't secure
Replace the wax motor and door lock mechanism.
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Philips SA52xx GoGear MP4 Player won't start up. It just starts starting up and freezes on GoGear, it also makes wierd crackling sounds when playing music... My Philips GoGear used to start up within 10...
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
May 31, 2009 | Philips SA3125\02 MP3 Player
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
