I need a coded diagram from the pcm to the end of the harness that plugs to the transmission
  • 245 Answers
Hi
Your question posted in the computer section.You need to re-post it in the Auto/Truck section.
Bob
Posted on Aug 20, 2010
2005 avalanche 1500 4 x 4 won't shift from 2nd to 3rd or 4th gear
could PCM be problem ???? sure , so could a lot of other thing's ! You know how to test electrical circuits using a wiring diagram an a DVOM - digital volt ohm meter ? How to test shift solenoids ? How to test power an ground at the PCM - engine computer ? You don't want to just replace the PCM , needs to be programmed . Dealer . Not having it done will cause more problems then you have now > NO transmission shift solenoid DTC'S - diagnostic trouble codes ? Transmission mechanical problem .
Your best bet , take it to a qualified repair shop.
Feb 08, 2018 | Cars & Trucks
2000. What are the probable causes for DTC P0720?
the output speed sensor is not at fault; check the fluid level in the transmission. If that won't help, the transmission is bad.
Jul 27, 2015 | Honda Odyssey Cars & Trucks
What is a pcm on a 2.0 ford escort engine
Power-train Control Module
It is located under the stereo. Remove the center console (if it is a manual transmission, you'll need to unscrew the shift knob) and you'll be able to see a thick wire harness going under the stereo. There is a single 10mm bolt holding the harness to the PCM. Loosen this bolt (don't take it all the way out yet) and then use the harness to pull the PCM out far enough that you can grab it with your hands. Loosen the bolt all the way and pull the harness from the PCM and then pull the PCM out. On top of the PCM is the code, three letters and one number. You don't have to use the exact same code to replace this PCM, as long as you get it from the same "half-year" car. Before 1999.5 the cars used a 4-wire mass-air-sensor, after 1999.5 they used a 6-wire mass-air-sensor. You can safely use any PCM from 2000 and up as long as you get it from a matching transmission donor.
Jul 05, 2014 | 2002 Ford Escort
On a 2005 Ford Escape, which connector on the PCM feeds the COPs for # 3 spark plug?
You need a factory wiring diagrams for that
Helm.Com has ford factory diagram book, if your
willing to part with lots of money as I find necessary
Why not explain the problem
Seldom do you pin check end to end a harness
to resolve a problem
When your getting that involved you need the test
equipment & reference material & should be beyond
needing to ask for help
Can get the wiring pin out off ALLData at a local repair shop
Mar 06, 2013 | Cars & Trucks
Po75 code
Hi there:
This DTC P0750 refet at Shift Solenoid A Malfunction which means it could be PCM driver, wiring to and from the PCM to shift solenoid A or the solenoid itself. if the circuit was shorted you would have no reverse, if it's open you will have no 4th gear, so from this it would seem you have an open ckt. when you lockout o/d, then it has to stay in 3rd, which is why you can keep driving without it going into neutral on you. check your main harness plug in to the trans for any corrosion, wiring chafes etc. if you had a wiring diagram you could check resistance of the solenoid, it should be between 10 and 25 ohms, if you don't feel comfortable doing this, take it to a dealer.
Hope this helps.
Jun 02, 2012 | 1999 Nissan Frontier
On my 1998 crysler sebring I am getting OBD II codes of 40 and 41,Transmission & engine module,any suggestions where to start? Thanks.
code 40-
Possible causes - 1/1 And 2/1 O2 sensors harness circuit shorted
- 1/1 And 2/1 O2 sensors harness circuit connectors (wrong connection)
- Faulty Powertrain Control Module (PCM) P0040 CHRYSLER Description At ignition on the Powertrain Control Module (PCM) checks the voltage on the ground side of the O2 sensor harness connector. If voltage is higher than two volts the P0040 code will set. code 41- Possible causes - 1/2 And 2/2 O2 sensors harness circuit shorted
- 1/2 And 2/2 O2 sensors harness circuit connectors (wrong connection)
- Faulty Powertrain Control Module (PCM) P0041 CHRYSLER Description At ignition on the Powertrain Control Module (PCM) checks the voltage on the ground side of the O2 sensor harness connector. If voltage is higher than two volts the P0041 code will set.
Dec 01, 2010 | 1998 Chrysler Sebring
Engine swap. color codes are different need wiring diagram
I've done several of these swaps that sound good at the time but end up being a Huge problem.I would start with the correct harness for the engine you've put in.It must include the under hood harness and what ever harness connects to it thru the firewall to the computer.You'll also need everything connected to the transmission to the computer including any thing connected with the brake and accelerator pedals.Next get the wiring diagrams from Jeep or buy the Chilton or Haynes manual,they have the diagrams included.Get the harnesses connected to the engine,trans and computer,then work backward towards hooking up everything else.I really feel your pain,I've put 20 year newer engines in older cars,V-8's where 6's were,an olds V-8 where a in-line six was(ford),Late model v-8 in a 59' Chevy.All these were simple compared to what your going thru.Please contact me if I can be of any help?
Sep 28, 2009 | 1991 Jeep Cherokee Limited
Where can i get a wiring diagram on how to install my valet remote car starter in my 1999 Dodge Durango i can't seem to find the wires i need to hook them up to the romote starter
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS Ignition 12 volts D BLUE IGNITION SWITCH HARNESS Starter YELLOW IGNITION SWITCH HARNESS Dome Light YELLOW (-) AT COURTESY LIGHT UNDER DASH ** Trunk Pin TAN/BLACK (-) AT SWITCH OR CENTRAL TIMER MODULE * Parking Lamp BLACK/YELLOW (+) AT HEADLIGHT SWITCH Lock ORANGE/VIOLET 10 PIN CONN. IN DR #203 Unlock PINK/VIOLET KICK OR CTM * Tach Signal BLACK/GRAY AT IGNITION COIL OR PCM * tab_rs.gif Ignition #2 BLACK/ORANGE IGNITION SWITCH HARNESS Ignition #3 D GREEN/RED ** IGNITION SWITCH HARNESS Accessory BLACK/WHITE IGNITION SWITCH HARNESS Neutral Safety BLACK/WHITE (-) AT SWITCH ON TRANSMISSION OR PCM * Brake Light WHITE/TAN (+) AT SWITCH ABOVE BRAKE PEDEL Reverse Light VIOLET/BLACK (+) AT SWITCH ON TRANSMISSION Rear Defrost N/A TIMER BUILT INTO SWITCH
Hope this helps
Jan 26, 2009 | Directed Dei Valet 561r Remote...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
