Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Runs good at 2000 rpms pops and skips at idle
    Problem Solver:
  • 7 Answers
Try changing spark plugs first.
Posted on Aug 21, 2010
2000 ranger missfires on number6 , runs good over 2000 rpms
It's still misfiring. The engine is running to fast for the computer to pick it up. Pull the plug wire on 6 , start the truck. look for spark out of the wire. No spark, replace the coil pack. Spark, pull the plug,see if it is fouled out. I would do a compression test also, while the plug is out.
Jun 11, 2016 | Cars & Trucks
My 2005 rev STI 600 show it is idling very rough and runs pretty good until about 6000 rpms then is skipping and popping pretty bad can't get much over 60 miles an hour out of it the pipe has a dent in it...
6000 RPM is high. IF there is a check engine or service engine light on, you need to go to a big auto supply store like autozone and have them scan it for free.
Feb 25, 2015 | Cars & Trucks
Rough idling 2000 carbureted heritage classic
It sounds as if you may have some partially contaminated fuel entering the carbs. About the only other thing I can imagine that would cause this is a very small vacuum leak at the point where the carbs mount. Carbs have even been known to shake loose at the air horn to main body gasket. Good luck!
Oct 18, 2014 | 2000 Harley Davidson FLSTC Heritage...
Rough idling when warm heritage
Sounds like it is sucking in air from somewhere. Check between carbs or other gaskets. Good Luck
When i start my 2000 grand am gt my cars rpms rev up and down till it levels out were the rpms should run at when idling
Have the idle/air control valve checked, the pintal inside could be stuck or just needs cleaning.
Sep 08, 2011 | 2000 Pontiac Grand Am GT
97 ford expedition cutting off at idle . it was skipping and hesitating under strain . had it checked by a computer and it said egr valve and number 6 cylinder misfire . i changed egr valve , plugs, wires...
pull wire off # 2 see if idle changes if not there s no spark... test coil....test all vacuum lines for leaks also. if all good then idle speed sensor.
Mar 20, 2011 | 1997 Ford Expedition
I can't get my Fz750 to idle. Engine runs great above 2000 rpms. Will not run below 2000 rpms. Stalls. Have completely cleaned the carbs. Jets seem good. New Plugs. New fuel filter. Any ideas? Thanx
You need to sync the carbs after removing them it wont idle if they are out of sync.
When were the valve clearances last checked? It wont idle if they're out.
If you alter the valve clearances you shd sync the carbs after
Ride-Safe
Bike-Doc
Please mark this as helpful (if it has been!!)
Aug 14, 2009 | 1986 Yamaha FZ 750 AE (U.S.)
With clutch pushed-in, RPMs start to go up to around 2000-2500
if it isnt the iac probably the pcv valve positive crankcase vent. it is on a vacuum line somewere under hood. or check the air cleaner, the hose with the small filter underneath the air filter. i take its fuel injected?
Feb 16, 2009 | 1987 Ford F 150
Lands Phones Logo
37 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
