Universal remotes are not gauranteed to be compatible to every type of TV set. There are just too many variences over a very large span of models for the manufactures to handle.
Normaly, the universal remotes will only do the basic functions of the set, and some of the menu functions but on a limited base.
I would suggest to persue in getting the original remote. This should work for sure.
Jerry G.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
