Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
Microwave is dead. Does it have a fuse? - KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
  • 3,037 Answers
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Posted on Aug 20, 2010
My Intellichef microwave model #K0936 has stopped working. I've tried different outlets but the microwave is not responding. Is there an internal fuse that has blown or is the microwave dead?
If the fuse is blown the microwave will be "dead". The fuse is accessed by removing the cover. You can usually find the fuse by following the power cord into the microwave. Unplug the microwave and don't touch anything except the fuse as the capacitor can hold an electrical charge.
Nov 02, 2017 | Microwave Ovens
We have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Feb 24, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Dead Microwave - Internal Fuse?
After replacing the internal fuse (see other posts to see how I did it) the microwave is working fine (so far). We have used it 5 or 6 times without any issues.
Jan 23, 2010 | KitchenAid KHHS179LSS Convection /...
Unit dead Unit is dead - suspect blown fuse
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
The reason for this is that if you do not have any experience and training with microwaves, you can get a SEVERE shock, even if the oven is unplugged. THAT being said, if you still want to know where the fuse is get back to me. good luck.
ALSO, as you may know, a small microwave these days is under fifty bucks at walmart.
May 20, 2009 | Sharp R-1880LS 850 Watts Microwave Oven
Microwave has stopped working after being run empty for a short time. Is there a fuse that needs to be replaced or is the microwave dead?
There is a fuse inside the oven. The rating of the fuse may be 8amps. It is not suggested to run the oven without load inside.
May 04, 2009 | Kenmore 63252 Microwave Oven
Please help me
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Jan 02, 2009 | Sharp R-242 Microwave Oven
Completely Dead
there is a fuse in the top right hand of the microwave it will burn out when the Capacitor goes bad it will burn it out replace the Capacitor diod and fuse
Jan 05, 2008 | Thermador MBBS Microwave Oven
Sharp R-4A56 microwave oven dead
Did you check your circuit breaker to be sure that it wasn't tripped?
Jul 23, 2007 | Sharp R-202EW Microwave Oven
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
55 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
