Question about Brother PT-65 Personal P-Touch Electronic Labeling System Printer
My label maker is a Brother P-touch Extra PT-310 I
My label maker is a Brother P-touch Extra PT-310 I changed the batteries and put in a new label cartridge and the machine will not print. What can I do?
Democritus
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
  • 5 Answers
SOURCE: brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
Posted on Jul 28, 2008
  • 7 Answers
SOURCE: Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Posted on Apr 09, 2009
  • 13433 Answers
SOURCE: Need user manual
Hi
heres the user manual
http://www.ptouchdirect.com/ptouch/umpt80.html
Thanks,
Ekse
Posted on May 06, 2009
paul7of9
  • 1189 Answers
SOURCE: too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Posted on Jan 04, 2010
P-touch extra label maker is printing upside down and back to front
You have turned on the "Mirror print" option.
Here is a link to the manual. Go into the print functions and look up the Mirror Print option, that will show you how to turn it off:
May 08, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
Won't turn on after changing to new batteries
Did you put the batteries in correctly? It could be that simple.
Mar 20, 2014 | Brother P-touch PT-90 Personal Label Maker
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
When I try to print with my Brother PT-1200 label maker, it says "ERR" and does nothing. I changed batteries and the label cartridge but still nothing.
open the back of the label maker. remove the cartridge. in the lower right hand corner of the where the cartridge fits, there are 3 little posts that are pushed in when you insert the cartridge. find the holes on the cartridge that fit over those posts. cover the holes on the cartridge with tape. reinsert cartridge. try again. worked for me. If you push in the posts individually, you can figure out which one is giving you the error message. I'm not sure that it really makes a difference. I taped over all three holes and it worked fine after that. i realize its not a perfect fix, but may allow you to print anyways!
Jun 08, 2011 | Brother P-Touch PT-1200 Label Printer
Too much tape
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
I have lost my direction for my PT 80 Label
hi!
here's the user manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_1180_EN_132.PDF
hop this helps.
Sep 23, 2009 | Brother P-Touch 1180 Label Printer
How and where do I feed new labels
press and hold the code button and press the "space button" this will feed the tape
Feb 18, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT-85
Make sure you have fresh batteries, It sounds like the batteries are low,
Lou
Aug 10, 2008 | Brother P-Touch 1180 Label Printer
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT-65 Personal P-Touch Electronic Labeling System Printer Logo
1,706 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
