Question about Intex Pool & Spa
How do i clean or replace the filter on the intex water pump for my above ground pool
  • 43,501 Answers
Shut off the valves on the hoses coming from the pool. spin the top of the filter counterclockwise to take it off. remove the old filter, replace with new filter then replace the cover and spin it tight. openvalves and purge air from the pump.
heatman101
Posted on Aug 20, 2010
  • ernest frasier Apr 09, 2011
    Just get a ezcleanfilter for your pool,no more replacing filters.
Just replaced my 1000 GPM Intex filter/pump with the 1500 GPM. Worked great for about two weeks. Now it doesn't pump much with the filter in. Seems to pump fine without the filter.
The filter needs to be cleaned. the cartridge should be removed from the housing and sprayed on the o with a hose and sprayer. A strong, concentrated jet of water works best. I hope this helps.
Aug 15, 2011 | Intex 1500 Gph Swimming Pool Filter Pump...
My intex salt water system alarm goes off and code 90 is flashing and there is little flow. If I take out the type A filter to the pump that came with my Ultra Frame above ground pool, the flow is...
What you need to do is either clean out the filter cartridge or replace it with a new one. If you have a spray nozel for your hose you can clean the cartridge by adjusting the nozel so it is a small but strong stream. Run the stream up and down on the cartridge until all the area has been covered and then install it in the system. If you still have little flow then you should replace the filter cartridge.
I hope this helps.
Jul 05, 2011 | Intex Automatic Salt Water System for ...
Very weak suction on inlet side. Water is green.
unscrew the top valve on the filter carteidge and let the air bleed out
clean filter every day and run it 24/7
Intex pumps can not filter good enough
Jun 09, 2010 | Intex Automatic Salt Water System for ...
How do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
How i change the filter on my intex pool
Unsrew 'white' knob on top of filter box.
Remove paper filter - clean or replace.
(use garden hose and blast filter clean)
Jul 06, 2009 | Intex Above Ground Pool 530 gal/hr Water...
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Pool & Spa Logo
75 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
