Question about Water Pik Hand Held Shower
The holder/water connection is broken where it attaches to water supply where can I buy a replacement part?
  • 35 Answers
Go to home depot or lowes to look for the faucet if it is sold there and ask them about parts. The other thing you can do is call the faucet manufacturer to see if a part is available. It's hard to tell what part you need without seeing the faucet and what on it is broke.
Posted on Aug 20, 2010
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
How to install 12 volt led light bulbs in the 220v Power Supply
Buy a lamp holder and 220V AC to 12V DC power supply, power supply should exactly be connected with the positive and negative holder, plug in the power, 12 volt led light bulbs can be used.
Dec 01, 2011 | Cars & Trucks
For some reason, after 5 years, a small leak has developed where the hot water exits the autocirc2 tank when you turn the hot water on. I removed the fixture where the plastic tubing hooks on and the only...
It's true, nobody has 100% perfect answer for broken stuff.
Open following link for some autocirc resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
If I understand correctly, you removed supply line that connects autocirc pump to the hot water shut off valve.
Buy standard sink supply line at local box store or plumbing supply.
If memory serves, the supply line is 1/2" IP thread that connects to pump and 3/8" Compression fitting that connects to shut off.
You might try using thick-bodied white teflon joint compound to help seal the connection.
I use rectoseal on threaded connections and tubular drain connections to ensure forever seal:
http://waterheatertimer.org/images/rectoseal-006-400.jpg
If brass part of pump is cracked, then autocir may be bad.
I have no idea how to permanently fix a broken brass water fitting, and would suggest replacement at that point.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | Laing Thermotech Autocirc Undersink...
It is an Aprilair Humidifier 220 with thermostat control. The unit is attached to the furnace and for 3 days, we have had water on the floor! We just moved in 2 months ago and are not familiar with a...
Check the drain on the humidifier (at the bottom there is a drain which should be attached to some type of hose that drains into your sump or other wastewater orifice)...
check the filter (remove the lid and the filter is that corrugated metal type thing (it may be clogged causing overflow - you can replace it for about 7bucks at home depot)
also check that the water line (should be attached to the black plastic frame is attached and the water is going into the top part of the black filter holder)
check that the filter is sandwiched properly within the black plastic holder
lastly check the actual holes in the black plastic filter holder to make sure they are not clogged
remember to bring the old filter to confirm size for the replacement
Jan 28, 2011 | Heating & Cooling
The holder for the ink cartridge is broken. Do I
Buy a kodak for 99.00 and the ink is under 5 dollars
May 27, 2010 | Dell 924 All-in-One InkJet Printer
NEED REPLACEMENT!!!
there are no replaceable parts in inkjet printers.. i can suggest if u just use it for home.. use cello tape to attach the piece if its out of warranty else.. u can buy a new printer with warranty for a cheap price starting v313 for $59..
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Connect water line and drain line
The supply line connects to the brass screw in fitting on the bottom left corner under the washer.
When you buy a dishwasher supply line kit, it will come with any adaptors needed. Unless you are using the steel braided line you will need to use teflon tape on the threads of the line. If you are using the SS line kit, you will only need tape on the adaptor.
Here is a pick of the line and the adaptor.
The drain line is attached with a typical hose clamp like this.
It is attached to the stub out on the garbage disposal if a GD is installed. If not then it is attached to the stub out on the drain pipe for the sink, like this.
Here is a pic of a drain line installed on a Garbage Disposal.
Oct 03, 2009 | Dishwashers
Flush valve is broken how do I fix it ?
Purchase a new flush valve at hardware store.
You'll need cresent wrench, locking pliers, small pipe wrench, small pail, towels, putty knife.
turn off water supply, flush toilet to remove water from tank, soak up remaining water with towel in tank, remove supply line from valve on botton of tank (you may have to hold valve with pliers inside the tank to keep from turning.) Clean area inside tank with putty knife where new valve will seat. Install new valve, attach supply line, connect overflow tube. turn on water.
Check for leaks.
Repeat if necessary. :-)
Sep 14, 2009 | Home
Fuse holders weakened and broken
Apart from somebody spilling something on them my best guess would be something in the amp seriously overheating. Check out the power section: transformer, rectifers, voltage control section for faults. The holders can be got at Maplin (uk) or Radio Shack (US), but find the fault first BE CAREFUL it could start a fire!
Dec 11, 2008 | Audio Players & Recorders
Water Pik Hand Held Shower  Logo
52 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
