Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Installed a new windows 7 computer, used install disc for the all in one 5300. Will not print anything from the computer, Copy function works, new ink supply, printing from the internet brings a message that the internet explorer has to shut down. Will not print from ay program. Mel
  • 1 more comment
  • mel_nwr Aug 19, 2010
    Duane,
    Thanks. I was able to uninstall the 5300 printer. Now I am unsure how to go about reinstalling with a driver from the website.
    Mel
    duane wong,
    I followed your instructions and now the printer is working.
    Thank you much,
    Mel
    Duane,
    It was the first time that I have downloaded a driver. Much easier than I thought.
    Thanks again,
    Mel
  • 3,083 Answers
Is your software package compatible with Windows 7? You might need a driver update, and here is one link:
http://www.massdrivers.com/dir/445010.html
It sounds like an incompatible software package, and perhaps getting a driver update with fix the problem.
Good luck, and hope this helps get it working.
Posted on Aug 20, 2010
  • Kodak Master
  • 6,826 Answers
Try to uninstall the printer from the control panel.
Then, install using drivers directly from the Kodak.com website:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9104/9106&product=EKN033540
Posted on Aug 19, 2010
  • Duane Wong
    Duane Wong Aug 20, 2010
    I'm glad it worked out for you.
Forgot user mane and password
How To Reset a Windows 7 Password
  1. Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
    Tip: See How to Boot From a CD, DVD, or BD Disc or How to Boot From a USB Device if you've never booted from portable media before or if you're having trouble doing so.
    Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free. See How to Create a Windows 7 System Repair Disc for a tutorial.
  2. After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
    Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
  3. Click on the Repair your computer link.
    Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
  4. Wait while your Windows 7 installation is located on your computer.
  5. Once your installation is found, take note of the drive letter found in theLocation column. Most Windows 7 installations will show D: but yours may be different.
    Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
  6. Select Windows 7 from the Operating System list and then click the Nextbutton.
  7. From System Recovery Options, choose Command Prompt.
  8. With Command Prompt now open, execute the following two commands, in this order: copy d:\windows\system32\utilman.exe d:\ copy d:\windows\system32\cmd.exe d:\windows\system32\utilman.exe To the Overwrite question after executing the second command, answer withYes.
    Important: If the drive that Windows 7 is installed on in your computer is notD: (Step 5), be sure to change all instances of d: in the commands above with the correct drive letter.
  9. Remove the disc or flash drive and then restart your computer.
    You can close the Command Prompt window and click Restart but it's also okay in this situation to restart using your computer's restart button.
  10. Once the Windows 7 logon screen appears, locate the little icon on the bottom-left of the screen that looks like a pie with a square around it and then click it!
    Tip: If your normal Windows 7 logon screen did not show up, check to see that you removed the disc or flash drive you inserted in Step 1. Your computer may continue to boot from this device instead of your hard drive if you don't remove it.
  11. Now that Command Prompt is open, execute the net user command as shown, replacing myusername with whatever your user name is and mypasswordwith whatever new password you'd like to use: net user myusername mypassword So, for example, I would do something like this: net user Tim 1lov3blueberrie$ Tip: If your username has spaces, put double quotes around it when executing net user, as in net user "Tim Fisher" 1lov3blueberrie$.
  12. Close the Command Prompt window.
  13. Login with your new password!
  14. Create a Windows 7 Password Reset Disk! This is the Microsoft-approved, proactive step you should have done a long time ago. All you need is a blank flash drive or floppy disk and you'll never need to worry about forgetting your Windows 7 password again.
  15. While not required, it would probably be wise to undo the hack that makes this work. If you don't, you won't have access to accessibiily features from the Windows 7 login screen.
    To reverse the changes you've made, repeat Steps 1 through 7 above. When you have access to Command Prompt again, execute the following: copy d:\utilman.exe d:\windows\system32\utilman.exe Confirm the overwrite and then restart your computer.
Aug 13, 2014 | Computers & Internet
How can i remove a forgotten password from a laptop?
Windows 8: Simply log on to an computer and change your Microsoft account passoword.
WIndows 7:
1. Use the password reset disk, if you have one.
2. Have an admin log on to his account and change the password for you.
3. "from about.com"
  1. Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.Tip: See How to Boot From a CD, DVD, or BD Disc or How to Boot From a USB Device if you've never booted from portable media before or if you're having trouble doing so.
  5. Once your installation is found, take note of the drive letter found in the Location column. Most Windows 7 installations will show D: but yours may be different.
  6. Select Windows 7 from the Operating System list and then click the Next button.
    copy d:\windows\system32\utilman.exe d:\ copy d:\windows\system32\cmd.exe d:\windows\system32\utilman.exe To the Overwrite question after executing the second command, answer with Yes.
    Important: If the drive that Windows 7 is installed on in your computer is not D: (Step 5), be sure to change all instances of d: in the commands above with the correct drive letter.
  11. Now that Command Prompt is open, execute the net user command as shown, replacingmyusername with whatever your user name is and mypassword with whatever new password you'd like to use:
    Important: Undoing this hack will have no impact on your new password. Whatever password you set in Step 11 is still valid.
Jul 01, 2014 | Toshiba Satellite Computers & Internet
Recover passwords
Here's How:
Nov 11, 2013 | Computers & Internet
Forgot password
Oct 14, 2013 | Computers & Internet
I have a problem with starting up my computer, when i press the turn on button it comes up with windows boot manager tells me to do 1. Insert your windows installation disc when i enter my windows 7 disc...
Hi there !
You operating system is corrupted and needs to repair or reinstall the operating system. But I suggest just run the repair mode.
If your windows 7 installation disc is not working, it means the Windows 7 installer DVD is not working properly, maybe the DVD have too much scratches or due to bad copy of installer DVD, (it is not working in CD, use DVD) try to use other Windows 7 installation disk and surely it will run the Windows 7 DVD set up menu.
I hope it helps you.
Jan 18, 2011 | HP Pavilion dv6000t 15.4" Notebook Laptop...
HP Deskjet F4480 will not print after vista to windows 7 upgrade. Ran HP printer diagnostic tool says driver conflict, uninstalled re-installed same problem, same diagnositics. Attempted to print test...
Windows 7 comes with basic driver built into the operating system (in-OS driver). With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot. When you connect the product to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Follow these steps to install the basic driver in Windows 7.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the product and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use the following workaround procedures instead.
For more options go to LINK .
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | HP Office Equipment & Supplies
I have an HP LaserJet 3015. I got a new computer
- uninstall everything again
- browse your disc
- open "Setup" folder
- copy "Scrubber.exe" and "scrubber.ini" to your desktop
- run "Scrubber.exe"
- restart PC
- reinstall software
- enjoy
- p.s. this will not work under windows 7
Jul 02, 2010 | HP LaserJet 3015 All-In-One Printer
I can print and copy, but when I scan to PC /pdf/e-mail it will not do anything despite the little window showing what I am on. Toy is brand new and right software was installed from disc onto Compac desk...
You must associate that function, PDF, Mail, with the right program, also of course you must have the program installed too. Of course you can also get say adobe professional and this allows you to scan from Adobe. Or use Word and scan it in to that, and save it (print it) as a PDF, or get DoPDF, this will, "Print" any image to PDF. As for email, simply open your email, & scan whatever whatever you want, and "attach it" to the email, and browse to where it is and select it.
Feb 08, 2010 | Office Equipment & Supplies
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Not printing
cancel all the pending documents pending in the print queue.then try
Aug 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
24 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
