Question about Vivitar 285HV Flash
Replace hot shoe - Vivitar 285HV Flash
  • Vivitar Master
  • 12,061 Answers
Red wire (positive voltage) goes to center pin. Black is ground, goes to outside shield or shoe edge contact. If the wires are reversed, a simple test switch will still work, but a photo slave will not (because it is powered from the +voltage so it depends on the polarity to be correct). Of course, the small PC contacts and cables can be unreliable so it could also be a bad cable. For much more detail and photos see: photo.net/photography-lighting-equipment-techniques-forum/00Po9t
Below is a utube Video of exactly how to do what you want
http://www.youtube.com/watch?v=gzb5-FUZzaE&feature=related
Posted on Aug 19, 2010
The foot on the hot shoe mount seems to be broken. I'm sure I can replace the part myself, but where can I find it?
You need to do some work on the web because you did not give us the make and model. Try these links they should get you started.
Konica Minolta Camera Repair Parts
USCamera com distributors of spare parts for digital film and video...
The foot on the hot shoe mount seems to be broken sure can replace the...
Samsung Galaxy Note 4 Rear Facing Camera Lens Cover and Bezel Fixez com
May 29, 2016 | Cameras
Auto flash does not pop up on Canon7D
This usually means the camera thinks there is something connected to the hot shoe, but there is nothing connected to the hot shoe. Likely one of the micro switches under the rails of the hot shoe is stuck, or you need to tighten the hot shoe. Here is a nice guide to fix this:
Jan 05, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
After taking the drum off I discovered traces of oil. Why?
Your wheel cylinder is leaking,is hydraulic fluid on your brake shoes,it will cause your shoes to get hot and crack.When replacing,do both sides with new brake shoes.
May 06, 2013 | Cars & Trucks
I have broke my hot shoe nissin (DI 622) where can i get replacement of the hot shoe....
I have broke my hot shoe (the contact piece that slides into the camera) is there a way to just replace that piece
Apr 28, 2011 | Nissin Cameras
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Ricoh KR10 Super
Try a camera shop that still repairs obsolete camera's, if you have all the parts it can be fixed or replaced ( top cover ) with a good used one . If your KR10 has a flash socket on the front of the camera buy a flash bar and use that. Be sure the loose wire from the hot shoe is not touching anything.
Oct 08, 2008 | Photography
Broken Hot Shoe
This link gives step-by-step instructions with pictures for replacing the shoe.
http://planetneil.com/tangents/2007/05/31/repairing-the-canon-580ex-hotshoe-foot/
Jun 16, 2008 | Canon SPEEDLITE 580EX TTL Flash
Removing the back to replace the LCD screen
On top of the shoe is a thin piece of metal. Using a small screwdriver this can be gently levered up at the front edge and slid out. Then access to the 4 screws is possible.
Mar 13, 2008 | Olympus SP-350 Digital Camera
Broken hotshoe for 550EX
http://www.uscamera.com/550ex.htm i did the same with my 430ex ordered part from url above. need to do a little soldering though.
Aug 21, 2007 | Canon Speedlite 550EX TTL Flash
Flash cable
The FL-CB05 Hot-shoe to Hot-shoe flash cable is approximately 3 feet (1 meter).
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Vivitar 285HV Flash Logo
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
