Question about Whirlpool Refrigerators
13 yr old Whirlpool Side by Side refridgerator model ED25PDQ DW03 quits cooling occasionally.. Sometimes for unknown reason... the cooling stops. I had Sears out.. either bad defrost timer or ? I replaced the defrost timer... still stops. I guess it might be the thermostat control which is located inside the top front chassis. If I pound next to the thermostat panel area... the compressor starts up and works again... until it quits maybe every other day.
  • 4,066 Answers
You can bypass the defrost thermostat the next time it stops working to see if that is the problem. Connect the two wires to each other instead of the thermostat.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 19, 2010
I have a 5 yr old hotpoint refridgerator. the freezer side works fine but my fridge side is hot. changed the thermostst but it did not fix the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Refrigerators
Refridgerator side stop working on whirlpool gold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The coils on freezer side freeze and refridgerator warms up
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge side not cooling. freezer works. 6 yr old side by side
There is a little fan that blows air from the freezer side to cool the fridge side. Pull the plug on the refridgerator for over night, long enough to give it time to defrost if there is any, then plug it back in and see ifthe fan is running. If not then it probably needs to be replaced. If it keeps frosting up and stopping the fan then the defrost timer is probably bad and will need to be replaced.
Nov 14, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
13 yr old Whirlpool side by side fridge temp. contol problem
Is your model the ED25PQXF ? Can you explain what you need to do manually to cause it to work? The thermostat? If thermostat is the answer the thermostat will need replaced. By straight wiring the 2 wires it turns refrigerator on. Let me know, Sea Breeze
May 19, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have a ed5fhgxkq00 side by side Whirlpool refridgerator that stopped cooling. It worked fine up until last night when we noticed that the ice was melting. Now it gets a little cool but not cool enough....
If the compressor has a fan next to it, be sure it is running. if the relay is clicking every few minutes it may need to be replced. contact local parts distributor.
Nov 04, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
