Question about Whirlpool Washing Machines
My whirlpool duets door latch broke and I ordered a new one and installed it and the door will not shut completely. Why will it not shut all the way. I can hold the button that indicates that the door is shut and try and start it and the coil for thelatch is trying to do something but does not rotate the latch. any suggestions?
    Champion:
  • 245 Answers
It sounds like you need the cabinet catch that catches the door latch.
Posted on Aug 19, 2010
  • ricklloyd2 Aug 19, 2010
    I have installed both, the catch and the latch
I have a Whirlpool GHW9400PL0 front loading washer. The door won't stay closed, and I think it's because the plastic latch on the base of the machine broke. The latch portion (white plastic) looks...
you have to inspect that switch carefully,, its actually got 2 , a secondary switch latches just before the spin cycle, I'll try and locate the part for you
Jul 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Our door latch broke (the one inside the face of the washer, not on the door) when the washer was spinning a heavy wet blanket that got out of balance. We have the new part in hand from Maytag parts. How...
The following link explains step-by-step how to replace a door latch on a Whirlpool Duet:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Read through the information I provided and let me know if you have any questions. An alternate method is to remove the washer top panel and work down through the top of the washer. Access can be a problem sometimes, however. I hope this helps you.
Nov 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door latch broke, I got the replacement part but am not quite sure how to install it.
The following link explains step-by-step how to replace the door latch on a Whirlpool Duet front loading washer:
If you have any questions about this repair, or need additional assistance, please let me know. I hope you find this information helpful.
Aug 29, 2009 | Whirlpool GHW9400 Duet Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Door latch
The door latch is electro-mechanical. Which means, it has a mechanical mechanism that is electronically controlled. If the latch is broken, it is recommended that you replace it. The following link explains how:
If you require a replacement latch, they can be ordered on line at searspartsdirect.com. Just type in your model number and locate item number 7 under the "Door and Latch Parts" heading. The part number is 8181700.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door will not shut
if the stike on the door is not broken then it is the door latch
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door latch repair
Try this link http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine&gclid=CPn0wqbb75ICFRQfsgoddySB5A
Apr 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool door pin location
No, unfortunately the door latch assy. comes as a complete unit. Part# 8182634. This # is for the entire door latch mechanism, not just the pin and lists for ~$45.00. Easy repair... open the door. At the 6 o'clock position of the door seal, begin removing the seal clamp with a small screwdriver by inserting it between the spring and the seal. Then peel the seal back (at the 3 o'clock position) to gain access to the latch assy. Remove the 3 screws holding the latch in place and pull gently out. Remove the wire harness. Install the new latch and rebuild. (make sure you position the seal clamp the same way it came off... the spring at the 6 o'clock position.) Install time= ~15 minutes. Job done! and well worth the 50 bucks!
Aug 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
