Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
One of the 2 coffee outlets is clogged, how to unclog it?
  • 1 more comment
  • miltonberger Aug 19, 2010
    This page and the manual doesn't say anything about how to unclog the outlet. For information, I tried the cleaning cycle but it didn't solve the problem.
    I've ran the cleaning program but it didn't solve the problem.
  • miltonberger Aug 21, 2010
    Haven't tried it yet but details are thorough, with photos and all. I'm certain it will help me solve the problem.
  • 10,515 Answers
I have a generic procedure that have helped many people. Look at :-
http://www.buessert.de/Technik/Jura-IMPRESSA-S95/Cleaning.htm
If that does not help, revert and i could search more information for you.
Good Luck!!
Thanks!!
Posted on Aug 19, 2010
  • kdn070 Jan 04, 2011
    Recently after using my Jura S9 I pulled out the tray to empty the water and grounds and found a snap washer in the drip tray (the rear onenext to the grounds container). The snap washer has brocken in half.
    Does anyoneknow where this snap washer has come from?
    Regards Dean.
  • 4,472 Answers
Refer to p. 24 of the manual for all the cleaning procedures. If you need further assistance please let me know. Also make sure to keep up with cleaning and this should prevent the outlet from clogging.
http://www.capresso.com/pdf/s9_instructions.pdf
Thank you,
Lee
I've purchased at least 3 Keurig Coffee machines Special Edition and it seems after 1 year which is the warranty my machine stops working. I can hear the boiling but it does not bring the water up to
It could just be clogged. Have you cleaned or descaled the unit? There are 2 places where clogs occur - in the head and in the output of the K-Cup. A good indication of a clog in the head is that you will see water returning into your tank through the clear plastic outlet. If you see this, open the head and find the large needle in the upper part (this is what pierces the K-Cup at the top. Stick a cake tester or extended paper clip up the pointy nozzle and move it in a circle to unclog anything that might be there. Then run it a few more times. Also, clean out the nozzle in the bottom of the k-cup area in the same manner. Hope thishelps
Feb 09, 2015 | Keurig Special Edition B60 Coffee Maker
My Breville BDC600XL grinder appears to be clogged and would put ground coffee into the basket. The grinder also slows almost to a stop. How do I fix it?
if this isa bed-bath and beyond unit?! take it bak!. and try the Braun coffee grinder. I hav had mine for 10 years and nevr a problem.
Dec 31, 2014 | Breville Bdc600xl YouBrew Drip Coffee...
The coffee grounds are dry after the cup is brewed. It does not taste like fresh brewed coffee.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
Aug 23, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
http://centralvacproducts.blogspot.com/2009/01/how-to-unclog-central-vacuum-system.html
Oct 24, 2009 | Electrolux Central Vacuum
Clogged filter??
You can try to clean out the pic and glides on the K-cup receptacle. Let me know if this works. It should.
Mar 03, 2009 | Keurig B50 Coffee Maker
Coffee drip seems to be clogged?
changer de sorte de café le noir semble colmater les ouverture
Nov 21, 2008 | Saeco Odea Go
I need to clean my coffee maker and i have no idea how to.
Beleve it or not, if you want to clean a clogged coffee machine, add to the well a cup of white vinegar (inside the water reservoir), with no water, and let it work to percolate the vinegar. The fumes are bad but it will unclog the filtering. Be sure to put water (no coffee) and percolate with no coffee at least 3 times and you have a clean coffee machine.
Jul 30, 2008 | Krups Bravo Plus 872 Espresso Machine
Capucinatore problem
I had same problem. You may need to descale first and if still a problem the steam valve may be clogged. First make sure the cappuccinatore lines are clean). If steam valve is clogged there is a trick to get it unclogged,- by tapping steam valve to loosen it up- but suggest contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 09, 2008 | Saeco Royal Professional Espresso Machine
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
http://www.beamvac.com/usa/
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
352 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
