Question about Toshiba Satellite L505DES5025 Notebook
Hi, I have a Toshiba L505d-S5992 laptop. About a month ago I was getting on a plane for vacation and the day before I wanted to turn off my wireless connection. So to do that all I did was press FN F8 on my laptop. I also turned off a few things on the startup menu but I'm not sure if I disabled anything that would be important to this. So right now I am hardwired into my router but I need to get my wireless working within the next few days. Getting back to me ASAP would be very much appreciated. *Side notes* My brother suggested that I try using a Linux/Knoppix live CD, so I tried that and still couldn't get my wireless working. And yet the hard connection still worked. Im wondering if my Wireless chip just doesn't work now. It would seem strange because the Wireless stopped working a day after I disabled it. Also, when I go into my PC doctor thing, it tells me yes "Wireless connectivity is disabled" and tells me to search for the switch on my laptop. Well the only switch would be my FN F8, so I'm thinking if I get that fixed first, it will all work
shuttle561
  • 32 Answers
SOURCE: Fn+F8 hotkey dose not work but the remain FX go fine
Another Alternative is to check your BIOS to see whether or not your Wireless is turned on, if it is not pressent in your BIOS then update your BIOS Driver on the Internet to ver 1.4, Double check your version Compatabillity. Next if the adapter driver is installed, follow the following intructions: start -> settings -> control panel -> system -> hardware -> device manager -> now look for the wireless adapter, see if it is operational or marked with an error -> if it is marked check that it is configured for automatic, and also the resources. Set the configuration manually if so. restart the system.
1) Resource conflict = change resource settings
2) No adapter = check if the adapter is enabled (Y) then see if there is any conflicts (y) correct the settings e.g. resources and see if windows shows that the device is enabled (N) try to enable this device. If (N) then goto BIOS settings to correct it.
Hope this helps
Posted on May 24, 2009
leecom72
  • 4806 Answers
SOURCE: I don't know what fn f4 or fn f8 do.
Laptop keyboards can differ with the function keys and are set out different depending on make and model.
If you take a look at the F4 and F8 keys, is there any symbols (in blue) on them? If there is post back here with a description of the symbols, If there is no blue symbols on the keys then they will do nothing and there is nothing to worry about.
Regards.
Posted on Jul 16, 2009
kchilder
  • 72 Answers
SOURCE: make sure wireless switch in on
For many of the staelites there is a switch on the right side
Posted on Nov 22, 2009
  • 135 Answers
SOURCE: My l505d-s5992 toshiba keeps freezing up, I tried
could be a virus try system restore and go back to the earliest restore point
Posted on Apr 13, 2010
byteguy
  • 2229 Answers
SOURCE: I recently got my Toshiba Satellite A500-025
I would call Toshiba about it. I think they may have left the antenna wires off of the wireless card. Of course, you can disassemble it yourself and see if that is the case, but if it's under warranty, it's on them!
Posted on Feb 15, 2011
How do I charge my battery
With a charger ;) haha just kidding! If your charging port is not working than you need to change it. Very simple to change on any laptop
Oct 09, 2013 | Toshiba Satellite L505D-S5992...
Battery wont charge
Unfortunately with a computer that old, the battery will stop working correctly and will no longer hold a charge. The only way to fix this issue is to buy a new battery. You can get them from Toshiba, but I would do some searching on the web first. You might be able to get it cheaper from another site.
I can't change the display to dual monitors
You may have lost the drivers. Reinstall then activate 2nd monitor in display settings.
Oct 13, 2012 | Toshiba Satellite L505D-S5992...
How to unlock toshiba laptop when is says locked
Wow, this sounds like a problem one of my customers had with his Toshiba. I'll have to look thru my invoices to see if it's the same model. Anyway the only way it can be removed is to contact Toshiba and tell them the problem and they will give you a UPS or Fedex Shipping Label and fix the problem at no cost to you. This is a known defect of theirs.
Mar 28, 2012 | Toshiba Satellite L505-S5966 Notebook
Loss my wireless connection
If you reformatted your hard drive, you'll need to reload the wireless card drivers for the computer. They are not part of Windows.
Feb 23, 2012 | Toshiba Satellite L505D-GS6000,...
Need to see location of cmos battery on a toshiba satellite l505d
It's soldered to the bottom of the motherboard,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L505-L505D/remove-laptop-motherboard-3.htm
Scroll down to Step 23 , and click on the photo.
Main article,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L505-L505D/remove-laptop-motherboard-1.htm
NOTE*
You will be unsoldering a solder connection on a BATTERY.
Need to be good, or the battery could bl-ow up.
Make SURE you have no Static on your body, OR use an ESD wrist strap, and connect the alligator clip to a Good ground source. (Average cost is around $3 to $6)
I hope this is because the laptop will not keep the time, and date.
You CANNOT reset a BIOS password this way.
Toshiba's have a small capacitor in line, that stores a small residual amount of power. Enough to keep that BIOS password set, even if the CMOS battery is taken out for days, weeks, or months.
There are two SMALL copper pads that are shorted out BRIEFLY, with a jumper wire.
http://www.fixya.com/support/t6645137-toshiba_l500_clear_cmos
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 12, 2012 | Computers & Internet
Cannot stay connected on wireless networks. Troubleshooter shows problem detected with wireless network adapter and a cable unplugged. I am running a toshiba satellite L505d with a realtek RTL8187SE...
Hi, Please make sure that you have turned on the wireless switch on your laptop because this is a message that usually appears if the wireless on the laptop is disabled.Also please update the wireless drivers for your laptop from the Toshiba website. Thank you for your time and best wishes for your effort.
Jan 08, 2011 | Toshiba (PA3212U) Wireless Adapter
I really need Internet so I tried hooking up my bluetooth to my laptop (toshiba satellite l505d-s5965) which apparently does not facilitate Bluetooth, is there any way to make it work?
Not sure what you are trying to do, bluetooth is a short range wireless protocol, this is not for internet access.
If you want bluetooth on your laptop, buy a bluetooth dongle, they are very cheap.
If you want internet without an internet account at home, buy a mobile internet dongle, they are about £15 a month for 2GB limit
Oct 03, 2010 | Toshiba Computers & Internet
Toshiba Satellite L505DES5025 Notebook Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
