We have an Amana ap148ds room air conditioner. We shut it off for awhile, now we can't turn it on again. We unplugged and re-plugged it and reset the circuit breaker. When we try to turn it on, the light comes on for about 2 seconda, then the STOP light starts blinking. What can we do to restart the machine?
  • rrouse31327 Aug 20, 2010
    The AC will not come on and stay on. The STOP light keeps blinking and we have to unplug it to get it to stop blinking. When we plug it in again, and push the ON button, the STOP light starts blinking again. We have tried resetting the circuit breaker - that's not working either.
    In order to reset the timer, we would have to have the machine on, correct? Or are we missing something. RR
    President:
  • 1,796 Answers
HI!! If air conditioner does not operate: o Check if unit is plugged in. The plug may have come loose. o Check if the electrical wall receptacle is of proper voltage. o Check if the circuit breaker needs to be reset or if the fuse needs to be replaced. o Check if the unit is in "Off" mode.
When turning on the unit for the first time after plugging it into an electrical outlet, the unit will start in a low fan cool mode. The temperature reading out on the LED will be the current room temperature. When turning on the unit during regular usage, it will remember the last shut off setting. If you want to operate the air conditioner as a dehumidifier, then adjust to dehumidify mode.
ON/OFF TIME SET The air conditioner has a 112 hour on!off builtin timer. To delay the start time for 1 12 hours at 1 hour intervals, simply press "Timer" key (or On/OFF Timer Key) to adjust the start time. Note that the unit has to be plugged in to an electrical outlet for the timer to operate.
Good Luck!! Please, Keep me posted!!
Posted on Aug 19, 2010
  • 1 more comment
  • Rene J Solis Aug 20, 2010
    Hi!!
    Have you drained the water?? I missed that point when you said the unit had been stored. This is a safety feature for all portable AC's, if the tray if full, they won't work, once water is drained, they start right up. Keep me posted!
    Working great now, thanks, RR
  • Rene J Solis Aug 21, 2010
    Thank you for using FixYa!
How do I recharge unit
call a service repairman probably needs the recharge fitting added as they do not come from factory with them on
Jul 20, 2015 | Amana 14,000 BTU Portable Air Conditioner...
What does the E1 mean on the display
I read that this is a filter problem. There may be more than one. Turn it off and clean the filter. For many window air conditioners this code is simply a reminder to clean the air filter. After like 750 hours of run time this code pops up and you have to clean the filter and then reset the unit before it will work again. To reset the code you need to simply unplug the unit and then plug it back in again. On other units you need to hold down the power button while you reenergize the air conditioner.
On another make of window air conditioner you need to push the "fan" button twice and then the "mode" button once to reset this code. Still another person found that the circuit boards where going bad and they had to replace them to get the unit to work.
Jun 08, 2014 | Amana ACD105E 10000 BTU ENERGY STAR ROOM...
I have a protable AC #AP148D from Amana I want to empty the water from the pan. where is the pan locate and how can i get to it
The pans are usually at the bottom of the unit. It may be a plug not a pan you remove to drain it.
Aug 02, 2011 | Amana Portable Air Conditioner
I cant find the booklet that goes with my Amana Portable Inroom AC. Model # ap148D
The Amana portable a/c units have their documentation at Haier America. The direct link to the manual you want is here: http://crm.haieramerica.com/PUBLIC/User%20manual%20AP148D.pdf . If you want to buy the manual, go to http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/AP148D/Other+Cables,+Cords+%26+Wires.aspx . Scroll down to the All Parts section and then find the Use and Care Manual for $4.56. (It is a special order.)
I also found a link to the manual for the AP148DS here: http://homeappliance.manualsonline.com/ex/thread/view/idThread/295978 . However, you need to be a registered user (free registration) to access the link. Click on the Get This Manual button and the registration/login will pop up. This may be a similar enough manual to help you use the A/C.
I hope this helps.
Jul 07, 2011 | Amana Portable Air Conditioner
I have an Amana AP148DS POrtable air Conditioner. Is there a way to turn off the LED light?
No, unfortunately there is not a way to disable the light unless you are to disassemble the unit and remove the light.
Jun 10, 2011 | Amana Heating & Cooling
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
BLOWING WARM AIR
Amana portable model AP148DS blows air turns on but will not cool.
Jul 10, 2010 | Amana Portable Air Conditioner
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
