FixYa.com
Tags:
GE Spacemaker  Microwave Oven
Another broken handle (by 2 users)
posted by Sabalew on May 03, 2008
Handle is broken at the bottom. Please recommend part # replacement that will be durable.
GE Spacemaker (JVM1631BB004) Microwave Oven
Comment by Sabalew, posted on May 11, 2008
Info was helpful, however, there are 2 sets of screws and only able to get at one of them even with the plastic trim removed.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Rec2fyme, posted on May 08, 2008
handle is broken on bottom, same problem. GE profile spacemaker xl microwave.
Best Solution
posted on May 09, 2008
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2385 votes
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Comment by MicrowaveSvc, posted on May 12, 2008
So did the exploded view not help?
Did you try rotating the handle to help remove it?
Rating Locked! (?) Sabalew has rated this solution as Helpful
Solution #2
Helpful (85)
mrappliance
Rank:Master Master
Rating: 90%, 6 votes
part# WB15X10023 all handles for this unit are plastic.. this is the only part # that will work for this unit. to replace handle just open door. there is a plastic trim that goes around door. you have to carefully pop that out to locate screws for handle.
Can you Help with these Microwave Ovens problems?
GE Spacemaker (JVM1640SJ) Microwave Oven
Installation of GE Microwave...
We now have a GE Spacemaker... Answer This...
GE Microwave vent fan...
Hi - I just read your solution... Answer This...
Microwave shuts off after a few...
My Microwave now shuts off... Answer This...
GE XL1800 model# jvm1851bh04...
When I plug in my microwave,... Answer This...
GE Microwave JVM1651
The microwave works, but will... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
