Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Freezer works fine air is circulating and temp. is zero degrees refer side is 60 degrees and air does not seem to be circulating. Settings are set on 4 as they have been for five years Do I have to replace a fan or what ????
    Champion:
  • 245 Answers
Check to see if your hear your evaporator fan is running in your freezer, then check behind the refrigerator and see if your condensor fan is running. Make sure your condensor coils are clean under your fridge. Your symptoms are leaning towards dirty condensor coils. Good luck!
Posted on Aug 19, 2010
The freezer works fine but the refrigerator will not get cold.
On most new refrigerators there is damper that opens and allows the cold air from the freezer to circulate through the fresh food side.
I have seen this same problem caused by over stuffing either the freezer side and or the fresh foods side. On the sides of the fresh foods section there are normally vents which allow cold air from the freezer side to flow. If these are covered up, the air cannot circulate and without air circulation, the temp rise.
Both freezer side and fresh food side work because air is allowed to circulate around your product. I saw a refrigerator that the bottom half was 70 degrees and top half 38 degrees. The shelf about halfway down was completely blocking airflow. Threw out a bunch of boldly items and bags, rearranged items so air could flow and unit started working properly again.
If the damper is not opening, I have seen them freeze shut. It may have to be thawed.
There is also on some models a recirculation fan that gets turned on to circulate cold air from freezer. If this fan burns out or is blocked, it may need to be replaced.
You can go to searspartsdirect.com with your make and model number and get a complete drawing and parts breakdown for most refrigerators. And more important, you can buy them and have the part typically in two days at your door.
Hope this help!
Apr 19, 2016 | Refrigerators
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Sep 15, 2015 | Frigidaire FGHS2342LF Gallery 22.6 Cu. Ft....
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
We have our Sub Zero model 650 frig set to 35 degrees, our usual temp, but suddenly it won't get lower than 50. Freezer seems fine.
Check for a fan motor in between the freezer and the fridge. Or you have a block of frost in there shutting off air flow.
Jun 28, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
103 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
