Question about Sharp 55R-WP4H 55" Rear Projection Television
I don't have the remote, the picture in the TV does not cover the entire screen, it shows about 4to6 inches of emptyness at each side, what can I do to make the picture cover the hole screen?
  • Sharp Master
  • 736 Answers
To adjust the picture size on the television itself you would need a Sharp remote because there is a view mode button on it but there may be another way. If you are connecting a cable box or satellite tv receiver box to this television that remote should have an hd zoom # button or format button or aspect button that would adjust the picture size. The tv would have to be in the right input and the cable box or satellite tv receiver box would have to be set to the proper resolution according to what this tv is supposed to be able to display.
Posted on Aug 19, 2010
Testimonial: "Thanks, it don't seem to work without the remote, I'll try to get on over the net"
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
My picture display is narrow and does not cover the screen.
Does the Genie box have screen settings in in? Sometimes hd will show in smaller screens. Makes the picture nicer. If you adjust the screen size with your remote the high definition "niceness" will not be there.
Jul 30, 2014 | Seiki Televison & Video
Picture size
This is the same problem I have (the picture being cut off on the edges). On your computer, you need to change to a native display.
For instance, 1920x1080 usually cuts an inch off of all sides, but it's meant more for videos where a little cropping isn't a big deal; not general screen use.
I believe the reason this happens is because with those other resolutions, 1920x1080 for instance, they are not your laptop's "native resolution", so in order to avoid scaling and stretching the image (which would degrade quality) they show its exact size, point by point, which is bigger than the number of pixels on your TV display.
Some TVs, like mine, have a TV option called "100% scale" that forces the picture to exactly fit to the screen. But this causes stretching and distortion if the aspect ratio of your resolution and the TV's whole screen are different.
Try something like 1366x768 or 1360x768 (some have both, some have only one of those). You should be able to find one or two resolutions like this that show the entire screen with full sharp clarity. It may even look better than 1920x1080 depending on your computer; find the best one that shows sharpness.
Feb 23, 2018 | Polaroid TLA-01911C TV
I lost my remote, and the picture is smaller than the actual screen by about 2-3- inches on all sides. how do i enlarge the picture to fit the screen?
This function u can't do it without the tv original remote.Try website like Remotes.com to buy the tv original remote.Than used one of those buttons on the tv remote like View Modes,Picture Sizes,Aspect Ratio,Zooming to do the adjustment for tv screen pictures sizes.
Jun 23, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
I just bought a new insignia LCD TV and the picture does not cover the entire screen. Instead of the 32 inch. diagnal I should, I have a 24 inch picture. Is there something I can do about it?
The "picture size" on the TV needs to be set correctly. You should have a "ZOOM" button on your remote. Press it a few times, cycling through the options... see if this fixes the problem.
Be advised, many (most) HD channels do not show HD content all the time. At the broadcasters discretion, they may choose to ADD the black bars to either side (and/or top an bottom) of the image. This is what the "ZOOM" button is actually for... to allow you to correct this, filling the screen with the image.
*Note: many cable box have a "FORMAT" or "HD ZOOM" button. When used in conjunction with the TVs zoom feature, you can end up having one device set correctly, while the other is not. The result is often a picture that is expanded far beyond the bounds of the displayable area of the screen. If you can not find a solution using the "ZOOM" button, pick the setting which shows the most image. Now adjust the cable box setting (FORMAT / HD ZOOM).
Mar 06, 2011 | Insignia Televison & Video
Polaroid TLA-04011c 40 inch. LCD TV? How can u fix TV plasma screen? my friends kids hit the tv screen for with wii remote. i think they broke the tv screen from the one side. and how much it cost to fix...
Sorry this tv can't be fix acept replaced the whloe picture screen panel itself,the tvs screen panels are in of the limited production by the tvs industries,only can buy picture screen panel from the tvs themselves and it 90% important to the tv,will cost u the same as a new tv to get picture screen replaced.Sorry doesn't worth as a whole tv anymorre the tv now only worth as salvages tv for it electronic boards for spare parts for other tv,that it.
Dec 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Sharp 55R-WP4H 55" Rear Projection Television Logo
229 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
