Question about Dryers
Gas Dryer won't stay hot
I have an Amana Gas Dryer (PLG8409W2) which will not stay hot.
The igniter will glow and the gas will flow and ignite.
After a while (depending on the load) the flame will go out, it might then glow and ignite the gas flow again.
At some point the igniter will glow but the gas will not flow (and there is always a rattling) and the igniter shuts off.
The igniter will ignite the gas flow again if I stop the dryer, wait awhile and turn it back on.
I have already checked the following:
- cleaned the dryer vent, hose and vent chamber (in dryer base).
- vaccumed and cleaned everything I could see in the base (disassembled the whole air flow and cleaned)
- pulled out and cleaned the therostat in the blower chamber.
- This seems to occur in all of the modes (auto regular, perm press and timed dry)
- Have disconnected the dryer hose to eliminate blockage possibilities.
From what I've been able to read I'm guessing it's the igniter thermostat, the vent thermostat or the gas coils.
Any help would be appreciated!
Thanks,
Jim
  • 37 Answers
There is a thermoelectric eye that says it is OK to keep the gas burner on. If this sensor is defective or blocked from "seeing" the gas flame is properly lit, it will turn off the gas flow (safety) override solenoid. With the unit unplugged make sure that the optical path on the upper right (1:30 CW position) flame tube inside sensor window is clean. The rattle you hear is probably the safety gas shut-off solenoid engaging. If you need more help, please ask -- SWT
Posted on Aug 04, 2010
I don't hear the electronic ignighters
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
replacing whirlpool gas dryer ignitor not heating www goodappliancesupersto... How to Fix YOUR gas Dryer that is not heating up Part 1 rear panel
Jan 04, 2017 | Dryers
It dries great and doesn't continue to run, however, on/off light still stays on even after it's done.
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Air Flow and Heat
Warning
Jan 25, 2016 | Amana NED7200TW Electric Dryer
Gas dryer throws reset after a few minutes
Air Flow and Heat
Warning
Apr 07, 2015 | Dryers
Amana automatic dryer lga30aw won't push out gas and dry the clothes....any ideas?
Thermal Fuse
Air Flow and Heat
Warning
Mar 24, 2015 | Amana Dryers
Amana automatic dryer lga30aw won't push out gas everything else is working it just won't get hot.....any idea?
Thermal Fuse
Air Flow and Heat
Warning
I have gas GE Dryer Model DPSR483GA2WW that will not heat. Replaced selnoides and igniter. No difference. Can't see if igniter is glowing because view is from bottom of machine. Checked all thermo
Thermal Fuse
Air Flow and Heat
Warning
Dec 21, 2014 | GE Dryers
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Thermal Fuse
Air Flow and Heat
Warning
Aug 30, 2014 | Dryers
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Thermal Fuse
Air Flow and Heat
Warning
Aug 21, 2014 | Kenmore Dryers
The dryer only gets hot sometimes. The gas line
it could be the igniter or glow coil as it is sometimes called. if it is glowing orange in color it may only be igniting once in a while as it is on it's way out. the igniter needs to glow white hot in order to light the gas every time.
Oct 11, 2009 | Amana Dryers
Dryer does not heat up
do you see the igniter glowing if so it is probably the thermocouple
Jun 24, 2009 | Amana DLG330RAW Gas Dryer
Dryers Logo
470 people viewed this question
Top Dryers Experts
