Question about Refrigerators
Water dispenses from door but ice maker isnt filling ?
    Champion:
  • 245 Answers
Your inlet valve is bad, this part is located behind your refrigerator behind the cardboard panel. This part is not real expensive and is easily changed out.
Posted on Aug 19, 2010
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
I have a whirlpool model ED25PWXBN00 refrig and the ice maker is making ice but the part that holds and dispenses the ice has broken and no longer dispenses ice. what part do i need?
That depends if the ice maker continues to fill with water or just sits there with the ice slots empty. Sometimes it is the dual water control valve=> 4318046 Water Control Valve
and sometimes the ice maker itself. Does not hurt to have an extra part of each if you are a ice user like myself. If ice slots are empty fill with tap water and allow to freeze. If the ice drops and slots do not refill with water then replace the dual water control valve. 4317943 Ice Maker Assembly.
Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
Ice maker does not make ice anymore. appears the tray is not filling with water. door water dispenser is still working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Apr 24, 2010 | LG LRFD25850 French Door Refrigerator
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker is not filling w water. water does come
The ice maker likely needs replaced however it could also be the fill valve. If you have the ability to locate the valve at the end of the fill hose (usually bottom right when looking at the back of the fridge) it will have 2 solonoids with electical connectors on them. Swap the connectors and press the water dispenser paddle. This should fill the icemaker. If it does, the valve is fine and the icemaker is bad.
Aug 21, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool gold ice maker not filling with water to make ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
