Question about Maxis Sim Isle
When I try to install SimIsle I get the error "setup.exe is missing or damaged" I run windows vista
3 Suggested Answers
Mesmo
  • 164 Answers
SOURCE: Cannot Install
It might not run on vista. Vista in incredibly picky and most games needs patches. Best bet is to go to the sims website and see if they have the patch for vista.
Posted on Oct 21, 2008
SOURCE: Problem installing Caesar 3 on Windows Vista
Hi!,
I'm using a vista premium SP 1.. So I did got the above errors.
What i did was, explore the disc-->right click setup.exe and click properties--> compatibility tab--> select run for win xp 2 and under admin.
Then when I installed I choosed a MINIMAL install option. If you the the above step yet choose full the error comes up.
Should work :))
Its annoying to insert disc everytime when you wanna play because of the minimal installation option but i figured to 'burn' and .iso image to my hard disk and use a cd/dvd image mounting tool. This part is purely optional tho:P
Posted on Feb 07, 2010
I cannot install any software. NSIS error!
Hi
1.Go to "Start," click on "Run," type "cmd" in the text box, and then click on "OK."
2.On to the black window that opens up, click and drag the software installation file icon that you wish to install. For example, suppose you want install Google Talk on your computer and the setup file (googletalk-setup.exe) is stored in the "C:\\Software" folder. Click and drag the "googletalk-setup.exe" icon from the Software folder, onto the black window. Once you have dragged it, the entire path (C:\\Software\\googletalk-setup.exe) shows up on the black screen.
3.Press the spacebar on your keyboard and type "/NCRC". In our example, "C:\\Software\\googletalk-setup.exe /NCRC".
4.Press "Enter." The setup program will start now.
Note:
Even after following the above procedure, if the installation still does not start, then the installation file is damaged. Download a fresh copy of the software and try again.
May 29, 2011 | Microsoft Windows Vista Home Premium with...
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
Have Dorland's Medical Dictionary. Will not run.
hi it seems that the install location from where you are trying is damaged. if its from an external source try copying it to your hard drive and installing from there. if that fails then ur source is damaged. you can download a copy of the software
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Mar 22, 2010 | Computers & Internet
I'm having problems connecting. I ran the initial CD setup and everything seemed to run fine but when I try to access the 10.0.0.253 I receive an error message. The camera is set to wired and is...
"I receive an error message" (sic) What is it exactly, what happens? Also Install everything as Administrator, ALSO set the setup/install program's .exe in, Compatibility Mode for XP SP2. and Run the actual program's .exe as Administrator, too. Ensure all network settings are correct too.
Feb 22, 2010 | Panasonic BL-C131 Network Camera
Setup.exe has stopped working
If you are trying to install an older or possibly incompatible piece of software, you should:
1.)Navigate to the installer program (setup.exe) in Windows Explorer (My Computer).
2.)Right-click on it and choose "Properties".
3.)Choose the "compatibility" tab.
4.)Check the "Run this program in compatibility mode for:" box.
5.)Choose Windows XP (if you get to the end of these instructions and you get the same error, come back to this point and choose Windows 98).
6.)Click the "Ok" button at the bottom of the window.
7.)Go back to Windows Explorer (My Cmputer), and try to run the setup.exe again by double-clicking, or right-clicking and choosing "open".
Sep 19, 2009 | Microsoft Windows Vista Ultimate Edition
Trying to install Math Blaster from ''Knowledge Adventure'' on new vista 64 machine. error on opening setup is ''The program feature ''??E:setup.exe'' cannot start or run due to incompatibity with 64-bit...
Well I do know that "most" 32bit software can be installed on a 64bit windows, unfortunately this one maybe be an exception. I searched all over the maker's websites and could not find a single hint of 64 bit support. One other thing you might try is to right click on setup.exe and run as an administrator , but considering the error you are recieving I don't think it will help. I don't think it is possible, sorry.
Sep 14, 2009 | Computers & Internet
I'm unable to install Mortal kombat 4 in Windows XP SP 2. As soon as I activated setup, it exits with the error Msg "Start Menu Error". Please help
I've been trying to solve the same problem. Here's a solution I discovered that worked for the same problem in Vista; it may work also for XP.
To install and play Mortal Kombat 4 in Vista:
Click setup.exe.
Choose installation folder (create it later).
Get error message.
Do not click "Clean up."
CTRL-SHIFT-ESC and kill setup.exe process.
Create installation folder (selected during setup).
Copy all files in DATA folder on CD to installation folder.
Rename MK4.exe to Mortal Kombat 4.exe.
Install patch (optional).
FIGHT!
Regards,
Amillennialist
Feb 01, 2009 | Midway Home Entertainment Mortal Kombat 4...
Cannot install windows vista ultimate 64 bit on my computer when I have xp installed. Can boot from the 32 bit version disk though but I want the 64 bit. Tried booting it from start-up by booting from CD...
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
    Note When you receive with the Get important updates for installation message, click Go Online.
  5. Click Upgrade when the Which type of installation do you want? screen appears.
    If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
  6. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Nov 27, 2008 | Computers & Internet
Canon i250 printer will not work with window vista os
The Vista add-on module driver (whatever THAT means!) can be found here. Have you tried downloading this Vista driver already?
Hope this helps :)
Scott
Oct 06, 2008 | Canon Office Equipment & Supplies
Cannot Install
Oct 05, 2008 | Maxis Sim Isle
Maxis Sim Isle Logo
392 people viewed this question
Top Maxis Video Game Consoles & Games Experts
James Wishart
Are you a Maxis Video Game Console and Game Expert? Answer questions, earn points and help others
