Question about Dishwashers
Water wont go through dishwasher drying works dishes arnt getting wet
    Genius:
  • 1,073 Answers
Check to see if you have voltage at the water valve if you do the valve is bad if you dont then check the float switch if it is good go to the timer or control board
Posted on May 03, 2008
Why are dishes wet when cycle completed?
The appliance repair man attempted to solve all problems by replacing the control board. He may have overlooked a defective heater for drying the dishes.
Sep 03, 2015 | Dishwashers
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
How do I get the Electrolux dishwasher to dry the dishes?
Hello, I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why. Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's. Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further. I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment. Macmarkus :)
Jan 07, 2010 | Electrolux EIDW6105GW 24 in. Built-in...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
My dishwasher does not always dry the dishes completely - even though I use the same cascade with each use.
The most important thing to getting the best drying from this energy efficient, water conserving dishwasher is keeping the rinse aid dispenser filled. In my part of the US, I only see a rinse aid called Jet Dry.
The Cascade is the detergent powder and will not help the dishes to get dry.
Note: Even with the rinse aid full, some plastics will still be wet.
Aug 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Jan 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
