Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
It does not want to turn on. the display is not working
    Champion:
  • 245 Answers
Check your breaker box
Posted on Aug 19, 2010
Fridge freezer FFA47X DISPLAY OFF WONT TURN ON
I take it the fridge/freezer is working but no display. On the door that the display is not working take a look at the top hinge it will have a cover on it ( normally with a + screw in it ) take this cover off . you will see cables going into a plug and socket . Make sure this is nice and tight
Jan 23, 2015 | Refrigerators
Display not working on g12
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
Press once for Normal view in LCD viewfinder
Press twice to turn on Rule of Thirds grid lines
Press three times to turn off LCD display
Press and hold 1 sec. to decrease/increase LCD brightness
Jan 05, 2014 | Canon G12 Digital Camera
My Samsung GT-E2120 phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only...
My Samsung GT-E2120i phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only way to stop it is to remove the battery.what do I do to solve this?
Oct 27, 2010 | Samsung Eternity Cell Phone
As i turn on my laptop everything works except there is no display . before it happans sometime and when it turned on it works well. as i put it for 1-2 months after that it get started with display but...
Hi ,
The best possible thing which you can do right now is to check few more things ....As the problem doesnt have much to do on.
Try this::
1>Try to Notebook adapter to a different power outlet.
2.>If still doesnt work you can try to connect an external display us.
(if the external display doesnt work might be other issue but if the display works you have take it to the shop where they can work on this.
Hope This will work.
God bless you.
Sep 29, 2010 | Compaq Presario M2000 Notebook
I can find nowhere on the tv that has an on off button, just got this tv
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power
switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom
of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the
bottom of the display and disconnect the power.
Allso go here for full manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Oct 29, 2009 | Protron PLTV-32 Television
Display problem
Has the display every worked before? If so Sounds like the display setting is turned off. You will need to go into the menu settings and serch for display, then select yes or on for display mode. If that doesn't work the display may be burned out.
Aug 06, 2009 | Car Audio & Video
The radio and cd player work but cannot display anything
hi..make sure that u have turned on the
display button the set.once u have turned
off the display button in your set ur display
doesn't appear.This display option will be
available in the set.
check it out.
thank u.. rate me..
Feb 05, 2009 | 2005 Jeep Grand Cherokee
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
41 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
