Question about Horizon AFG 5.0 AT Treadmill
My Horizon omega III treadmill will not incline neither manually or with the appropriate programs.the machine is four years old but is in a private house and is only occasionally used.
  • 16 Answers
SOURCE: What silicone oil is needed on Horizon Paragon 408 treadmill?
You should be able to google the answer.
Posted on Jan 29, 2010
bwinton
  • 83 Answers
SOURCE: Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Posted on Apr 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
  • 218 Answers
SOURCE: treadmill turns off when increasing incline. New Balance 2500
there is a short in the incline the motor is bad
Posted on Aug 11, 2010
Testimonial: "I agree. The problem is that it requires servicing. My (cheap) fix is just to use it without changing incline! "
ercupa190
  • 12223 Answers
SOURCE: treadmill will incline but not stay up. incline # stays after bed lowers
incline Motor is not working it can be a few different things.
1) may not be any signal from the console which could be a damaged cable(tight the flexible cable from keypanel vs display board)
2) Tight the connector from display board vs lower board ( main motor controller board the console itself has failed.
3) The motor control board may have failed from a worn treadmill belt and deck measure 120VAC input for the board
5) the motor may have burnt out Test try to measure 120VAC.
6) potentiometer geared to the motor adjust it so the console knows what height the incline is at.
7) the gearing can slip, giving the console false information which can cause chassis damage.
Now see the block diagaram that I did , for person like you, for to know how the main motor board has aprox 90% of functions of any treadmills. sincerely. Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Dec 07, 2011
Ticking sound on horizon t101 treadmill
If you wish to get some details about treadmill repair; visit the site linked here. in the search tab put the world "ticking" and search.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Horizon Exercise & Fitness
Horizon T74 Treadmill powers on, programs and incline work, belt does not move and no sound from motor. What do I check?
Hi there, ....Sounds like a lower board issue. You can contact jatinahATrocketmailDOTcom for repairs on this style of unit. Good Luck!
Dec 07, 2016 | Horizon Exercise & Fitness
I have a Horizon HTM 3000 treadmill which is stuck on max incline and require the incline calibration code.
hi, i also have problem with my horizon htm 3000, incline motor stuck.
did anyone know where to buy brand new incline motor?
and how much it will cost?
Nov 16, 2013 | Exercise & Fitness
How to disable the beeping on a Horizon T61??
RUN the software calibration for easy diagnose, troubleshooting, and fix it.
However read your owner manual and follow the instruction in troubleshooting section, how to disable the beep.
Test the speed sensor+ reed switch, for open or defective, CLEAN it and tight any plug or connector.
see the block diagram
God bless you
Nov 17, 2012 | Horizon T61 Treadmill
Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Apr 19, 2012 | Horizon Quantum II Upper Control Board
Merit 725T. The treadmill has gone into a "10 degree" incline mode on its own, and will not respond to the control panel to reduce the incline.
Sep 21, 2010 | Horizon Fitness Merit Fitness 725T...
Horizon AFG  5.0 AT Treadmill Logo
63 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
