Question about Danby DPAC8020 Air Conditioner
COOLING AIR DOESN'T COME ON. TRIED SHUTING OFF,
COOLING AIR DOESN'T COME ON. TRIED SHUTING OFF, CLEANING FILTER. TURNING OFF CLOCK PULLED OUT WATER CONTAINER THEN RETURNED IT, GREEN LIGHT COMES ON WITH A FEW BEEPS THEN TURNS OFF.
  • 15,935 Answers
How many beeps please?
Thanks!!
Posted on Aug 20, 2010
Why is my ac window unit not cooling as well as it use to? .
Good Afternoon Friend,
I understand your Frigidaire air conditioner, model# FAC105P1A, is not cooling as well as it used to. Please try cleaning the air filter as well as the cabinet.
Air Filter Cleaning:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
• Push the vent handle to the Vent Closed position (where applicable).
• Open the front panel.
• Grasp the filter by the center and pull up and out.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
Cabinet Cleaning:
• Be sure to unplug the air conditioner to prevent shock or fire hazard. The cabinet and front may be dusted with an oil-free cloth or washed with a cloth dampened in a solution of warm water and mild liquid dishwashing detergent. Rinse thoroughly and wipe dry.
• Never use harsh cleaners, wax or polish on the cabinet front.
• Be sure to wring excess water from the cloth before wiping around the controls. Excess water in or around the controls may cause damage to the air conditioner.
• Plug in air conditioner.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FAC105P1A Window Air...
Carrier Air conditioners
change filter and clean outside unit with water. pull the outside fuze before cleaning.
Jul 29, 2012 | Heating & Cooling
The dehumidifier doesn't collect any water.
There are several things that can cause the problem:
1. The humidity extraction level is set to high. Lower it to 35%
2.The air intake filter is dirty and/or clogged. Remove the filter and clean it.
3. The cooling coils on the dehumidifier need cleaning.
4. Not enough clear air space all around the unit. Maintain at least a minimum of 12" air space all around the unit, while in operation.
5. The ambient air temperature at floor level is between 40 & 60 degrees F. This is particularly true, in basement applications. Raise the unit up off the floor onto something sturdy, that can maintain the weight (including a full bucket of water) and the vibration.
The above 5 things are the most frequent causes of your problem. Start your troubleshooting with these.
Hope this helps you solve the problem. Please let me know. Thanks.
Jun 06, 2011 | Kenmore Dehumidifiers
I replaced CVA-24 VALVE....now when I turn on pool filter no water being pulled through..no water being pulled through to pump
Your pump has probably lost its prime. This is either because it got too much air or not enough water. Try priming. This should make your pump start working again. Any time pool pumps have to be services, they need to be re-primed. In case you are not sure how, remove the pot lid and fill the pot with water. Re-add and clamp the pot lid. Open the air release valve on the filter and stand clear. Turn on switch or time clock. When water comes out of the air release valve, close the valve. If it is a two speed pump, make sure it is on high speed.
Aug 20, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
MY AIR CONDITIONER IS NO LONGER PRODUCING WATER FROM THE BACK
Check to make sure the filter is clean. If not, remove it, wash it and start it back up.
The water that you have seen comes from the machine cooling the air, the air conditioner literally squeezes the water out of the air. If it's not blowing cold ... no water.
If cleaning the filter doesn't work, you will probably have to have the unit looked at by a professional.
Jul 22, 2010 | Daewoo DWC-084R Air Conditioner
My xbox keeps shuting down due to ventalation issues. Ive tried to clean the system with an air dust remover but i still keeps shuting off. My fan runs super fast all the time too.
Most likely, you have your Xbox in an area where it does not receive proper air flow and ventilation. Your fan is overworking itself from the dust and the heat of the area you're sitting it in.
Try moving your Xbox to a more open area after cleaning it, and be sure to let it dry out after using compressed air.
May 18, 2010 | Microsoft Xbox 360 Console
I have a Craftsman Push Rear Bag Lawn Mower w/ High Wheel it's a 6.50 Briggs & Stratton Engine. I changed the oil by turning over the lawn mower and draining the oil from the dip stick hole. I also...
Your mower should definitely have an air filter whether it is paper or foam, and you should drain the oil from the bottom, not turning it over. turning it over can get oil in places where it shouldn't be and make it smoke or not run at all. It may need carburetor cleaning and spark plug cleaning or replacement, or the flywheel key may be sheared if it runs rough
Sep 27, 2009 | Garden
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Danby DPAC8020 Air Conditioner Logo
44 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
