Question about Dewalt DW744S 10" Portable Table Saw with Stand
Can i buy a new motor for my dewalt table saw?
  • 90 Answers
You need to check and see if it is the field or the armature that needs to be replaced. if you can use a volt ohm meter you can check these two items. you would use the ohm or continuity part of the meter. for the field, there is a wire coming fromthe elect source and the a spring around the brush holder. the are two of these field coils. if you take one leed to each end and the wire is ok the needle will move or you will see areading ont he digital readout. if you do not get a reading, there is a break in the wire and the field is bad. on the armature, using the same set up on the meter, hold one probe on the commutator. the commutator is at the end and is made up of copper rectangles. put one leed on one rectangle and then use the other leed to touch all the others one at a time. if you do not get a reading on one of the rectangles that means a wire is broke in the armature. if they both showgood, you have another problem. which would be your switch or cord.
Posted on Sep 02, 2010
4 Suggested Answers
  • 8 Answers
SOURCE: Dewalt Table Saw
I don't know about Cleveland, but a while ago I replaced the bearing on my Sears Craftsman saw, and it wasn't a hard fix. I would expect any competent repair shop could do the repair easily. If you can get the arbor off and take it to the shop, that would be ideal. It only takes loosening a few bolts to get it off. I first removed the cast iron top from the sheet metal base so I could turn it over, but it can be done from the bottom, too. Just be prepared to eat some sawdust. The most specialized thing the shop would need is a bearing press to get the bearing in and out of its seat, and many shops would have these; they aren't very expensive. Maybe a good machine shop which does small jobs could do it for a small fee. A good place to find these is at your local auto parts store, such as NAPA or O'Riellys (here in MIssouri, anyway, but you get the idea). Your auto repair shop probably knows one or two they use for 'turning' brake drums, etc. BTY, I didn't have a bearing press and I did the job with carefully tapping the bearing back on with a sleeve made from a piece of scrap pipe. Tauton Press makes a great DVD on tuning up your saw after this fix, as you want to make sure
it is square with the table in two dimensions - parallel to the miter saw slots and perpendicular to the top. Good luck.
dcm
Posted on Oct 01, 2008
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
deme-tri
  • 90 Answers
SOURCE: we have a DeWalt 744 table saw. The motor will not
check on the motor housing.
for a hump, that contains a capacitor ,
have it checked.try changing it with a different capacitor but the same (uf).
check to make sure that it works
Posted on Dec 10, 2009
How expensve is a motor for a dewelt porterable table saw
Most portable table saw are simply circular saws turned upside down and attached to the table.The price would be whatever they ask for the circular saw, would not be economical to try to buy just the motor.
Oct 08, 2017 | Saws
Dewalt 743 how to replace the brushes
If the motor body has two large screws on the outside, then you can remove them and install new brush set. If there isn't, then you have to take the motor apart and install them. Try to look up the saw and get a parts break-down picture or drawing first.
Mar 24, 2014 | Dewalt Saws
How to replace brush holders on dewalt table saw dw745
There is a small allen screw in the field housing holding the brush holders in.
Most often I have found, if the brush holders are needing replacement the motor housing also needs replacement - they heat up and the plastic cracks.
Dec 26, 2012 | Dewalt DW745 10" Compact Job Site Table...
How do i replace brushes on dewalt table saw
unscrew brush cap on each side of motor and pull brush out
do it reverse with new one
Sep 07, 2012 | Dewalt Saws
DeWalt DW708 switch
http://c.searspartsdirect.com/lis_png/PLDM/P0201024-00003.png
This is the newer 744 series, white cord to white motor and black cord wire to black motor.
If your motor needs the mag starter that 5th loose wire, usually red, goes to the start terminal on the mag starter.
Feb 14, 2012 | Dewalt DW744S 10" Portable Table Saw with...
Where do i buy an arbour for dw744 table saw
If you have a type number of 4, an assembly will have to be replaced, not just the shaft. THIS COULD BE DIFFERENT IF YOU HAVE A DIFFERENT TYPE NUMBER. It can be purchased online through DeWalt, but verify your type number before ordering.
http://servicenet.dewalt.com/Parts/Search?searchedNumber=153476-07&searchType=1
I hope this helps!
Nov 21, 2010 | Dewalt DW744X 10" Portable Table Saw
Tile saw stopped working
check the motor might have a reset botton or check the capacitor
May 31, 2008 | Dewalt DW746X 10" woodworker's table saw...
Dewalt DW744S 10" Portable Table Saw with Stand Logo
124 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
