I have no disc drive on my laptop how can i install my printer
    Sergeant:
  • 206 Answers
I would go to the Printer Manufacturers website and just download it from there. Works the same way, and chances are the driver on the disc is probably outdated. If you need help reply to this post and I will walk you through it.
Best of Luck,
DP
Posted on Aug 19, 2010
I had a MP 160 Canon printer in 3 how do I install it on my laptop
install the cd or find the drivers online follow installation procedures and put usb cable.......... there you are!
Jun 30, 2016 | Canon PIXMA MP160 All-In-One InkJet...
How can i install my hp deskjet d2460 printer to my laptop?
put the printer discin cd\dvd drive, connect printer usb cable to pc, waite for autorun of disc, will come window, and there install driver and software.
Jun 11, 2011 | Acer Computers & Internet
Replaced printer, same laptop with software. Inserted new DVD, but laptop does not give instructions for connecting printer.
It is possible that the auto-run feature has been disabled. Try opening the CD manually. If you have Windows, double-click on Computer (My Computer for older versions). Then double-click on the optical drive under Devices with Removable Media. Find the installer (exe for Windows, dmg for Mac) and double-click to launch it.
If the optical drive doesn't open, then you have a problem with the disc, the drive, the drivers for it or the registry properties for the drive.
If the disc install the Easyshare 5500, download the drivers for supported OS versions from here: http://support.en.kodak.com/app/answers/list/p/5,62,419/c/890/selected/true . Then double-click on the file to install. (If you plugged in the data cable (USB) to the computer before installing this software, uninstall the generic driver and then disconnect the data cable and reboot before installing the new software.)
Now to go back to the drive problem, if you were able to launch the file from the File Explorer (Windows), you may want to reenable auto-run. In Windows 7, click Start > Control Panel > Hardware and Sound > Autoplay. Set the line for Software and Games to Install or Run. You may want to check the box to Use AutoPlay on all media. If the optical disc could not be read, try cleaning the disc (if you see scratches) and try cleaning the optical disc lens. (Did you here the disc spin when loaded?) Check the Device Manager for a triangle with a red x or yellow exclamation point next to the optical drive. (Start > Control Panel > Hardware and Sound > Device Manager) Try to update the driver.
If there was no sound of the drive spinning, you may want to check if the power or data cable have become disconnected inside the laptop (either at the motherboard or the drive). See your laptop's documentation for opening it up or take it to be serviced at a local shop. You may need to replace the drive. An external optical drive can be used to replace the internal one and are fairly cheap. Most connect to one or two USB ports on the computer. The ones that take two USB ports do not need a power brick.
I hope this helps.
Apr 23, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do i connect to a laser jet 1020 dell
If the printer is new out of box then remove the printer out of the box with the Data cable and the power cable with the disc.
Connect the power cable from the printer to the power jack.
Connect the data cable from the printer to the USB port in the laptop.
Once this is done turn on the printer.
The system will detect the printer and a dialog box prompts the installation of the printer.
Then put the DVD on to the drive and from the dialog box choose the location as the CD/DVD drive as a source from where to install the software. This will install the printer and the printer is ready to use.
else
install the contents of the CD/DVD by accessing and double clicking the drive directly.
Sep 16, 2009 | Dell Inspiron 1525 Laptop
INSTALL LEXMARK X-5470 NO CD DRIVE IN ACER 1 LAPTOP
HI there if you follow the link bellow select the x5470 and then your operating system you can download the drivers and you wont need to install your disk
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Regards AL "alstech"
Jun 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Hello here! i have tried to install my lexmark x5150 to my compacq laptop, and cant get it to print, i have installed the disc countless times wiyh out any progress can you help?
Try this:
first uninstall the disc's software
than restart the laptop
if correct it will automaticly detect your printer and ask for the disk.
cancel the installation.
Insert the disk and cancel the automatic running program for installation.
go to start, printers, add new printer and follow the steps from there untill it says "have disk" click on have disc and brose to your CD drive. It will automatically indicate which program it requires, search on the disc that program and click OK and continue the steps.
Reason: automatic installations from manufacturers sometimes do not install all files needed by windows, installing via windows itself it will automaticcaly pick the correct files from the disc.
Jan 28, 2009 | Lexmark X5150 All-In-One InkJet Printer
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
My new c 4380, the disc will load and install on my vista laptop, but cannot get disc to run on my xp desktop, drive will not read it
I downloaded relevant info from HP web site and was able to install everything without the disc. And it never cost me an extra penny.
May 18, 2008 | HP Office Equipment & Supplies
Unable to install on laptop
Having problems installing my z600 printer on my hp laptop.
Dec 07, 2007 | Lexmark Z600 InkJet Printer
11 people viewed this question
jasbo
jasbo
