Question about Amana Refrigerators
I have an older AMANA 22 W/top freezer. Everything stays cold/frozen but I get alot of water leaking from the freezer to the fridge. What could cause this?
    Champion:
  • 245 Answers
Your evaporator drain line is clogged. It is located in your freezer behin th back panel.
Posted on Aug 19, 2010
I have an older Amana Top Freezer Refrigerato tc22g-wr. I believe it is an Amana 21 or 22. I am getting a lot of water inside the refrigerator. Coming trew the top plate vent holes. I think that a drain...
you have to defrost the freezer and open the back freezer wall with a thin hanger insert it in the drain hole and clean out all the dirt then pour a little water to make sure it goes down the drain, hope that helps, Joel
Sep 05, 2011 | Amana Refrigerators
I just moved into an apartment that has a side by side amana 22 refrigerator in it. The freezer section is fine everything is frozen and the tempeture is where it should be. The fridge side however, is...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Amana Refrigerators
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
Amana Model #TX20NBW FREEZES food in the fridge AND leaks water
Sounds as if the thermostat setting is too high.
Not a good idea to pour warm water into the fridge while its going, but then again.Most drain tubes exit over the compressor into a container sitting atop it. But I've since learned there are now fridges that don't have compressors now? You should also check the door seals, you can do this with a sheet/piece of newspaper
inserted between the door and fridge, go around both doors, you'll soon know if the seals need replacing.
Oct 03, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Water leaks from vents in fridge
This could be your heater has malfuncutioned and what is happening is that when you turn it on the freezer is trying to get cold and frost and the heater is staying on and letting things melt very fast and causing a water problem
May 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from top to bottom
Refrigerators typically have vents for COLD freezer air to travel to the refrigerator side. Make sure you do not have these blocked with frozen foods, or ice. A good defrost of the freezer may be in order. (I just went through this one week ago).
If the cold air does not travel down to the fridge to keep it above dewpoint, moisture begins to form quickly.
May 19, 2009 | Refrigerators
Fridge & freezer not cold enough
EASY FIX. TAKE ALL FOOD OUT OF FRIDGE AND FREEZER AND STORE IT.
THEN UNPLUG YOUR FRIDGE FOR 24HOURS WITH DOORS OPEN.
YOU WILL HAVE TO CLEAN UP ALOT OF WATER. THEN CLEAN THE FRIGE.
WHEN YOU PLUG IT BACK IN IT WILL WORK.
BUT THIS IS JUST A TEMP FIX. IT WILL HAPPEN AGAIN IN ABOUT A YEAR OR TWO.
TO GIVE U A MORE PERMANENT FIX WILL TAKE SOME TIME. TRY THIS FIRST.
Apr 30, 2009 | Amana ARB220ZC Bottom Freezer Refrigerator
Refrigerators Logo
69 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
