Question about Toshiba Gigabeat S30 MP3 Player
Gigabeat blank The screen has the blue background image but no menu items. How do I restore the software with the menu selection?
    Problem Solver:
  • 24 Answers
That's an indication that the media center program has loaded but frozen at a certain point [blue screen] before fully loading.
indicates a hard drive problem... prolly the head can't read the hard drive...did you drop it?
cuz when i dropped it...that happened to me...it froze on the menu...then i used the battery button to turn on n off..till i got the "contact the manufacturer for repair" with a yield sign message. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
Posted on Jun 07, 2008
What does the blue light in the corner of the screen mean
Sorry could not find the exact manual. however you can find it from this one as they ought to be similar
http://www.vivitar.com/files_products/1033/ViviCam_F124_Camera_Manual.pdf
It is called the METERING MENU - three modes (Centre; multi and SPOT). you are set for that spot. you can change that. see page 23
The Metering setting will affect how your camera focuses when capturing an image. Depending on your selection, the camera will be more sensitive to focusing on particular areas in the display and adjust the image color and lighting accordingly.
Center - Averages the light metered from the entire frame, but giving greater weight to the subject in the center
Multi - Used in standard conditions the camera divides and adjusts the settings of the image into several zones for light metering such as complex light conditions, position of subject, brightness, background, direct light and scenes
Spot - Meters the area within the spot point frame at the center of the LCD to set the exposure on the subject in the center of the monitor.
1) Press the M (MENU)/SET button to open the menus for the current mode.
2) Press the LEFT or RIGHT direction control buttons to scroll and select the chosen menu.
3) Press the UP or DOWN direction control buttons to scroll through the menu options.
4) Press the M (MENU)/SET button to select the desired option.
5) A selected option icon will appear on the selected item.
6) Press the LEFT or RIGHT button to select the next menu item. 7) Press the MODE button to exit the menu and return to your previous mode. 23
8) An icon reflecting your selection will display on the LCD screen 9) Remember that this setting will be saved by your camera until you manually change the setting or restore the camera?s default factory settings.
Apr 12, 2016 | Vivitar ViviCam 3188 Digital Camera
Tip
How to Restore Deleted Items on a BlackBerry?
BlackBerry comes with special software that helps you manage your files. It includes a feature that lets you create regular backups of your blackberry so that you can restore items that get deleted. While you can choose to restore all items on your phone, the software has an advanced setting that lets you choose to restore specific files.
Instructions
1. Connect your BlackBerry's sync cable to your phone and to an available USB port on your computer. Open the BlackBerry Desktop Manager software. 2. Select "Backup and Restore" on the main program screen. Click "Restore" and select a backup file if you want to restore all items on your BlackBerry. 3. Select "Advanced" if you want to restore specific files. Choose "Open" from the "File" menu and double-click a backup file to select it. Choose the database you want to restore under "Desktop file databases" and click the right arrow next to it.
on Jun 06, 2011 | Cell Phones
Desktop background doesn't show
I get this too. (Love using the solid blue background)
1. Check if there are any other users logged in on the Mac.
2. Log off all the users including yourself
3. Log in only on your user account and change the background
If that doesn't work, restart first and repeat.
If even that doesn't work, change to another solid background first and then change it back to the picture.
Dec 18, 2013 | Apple Mac Mini Desktop
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
Flashing background
On a Windows 7 system, right-click on a blank area of the sceen, click on Personalise at bottom of menu and select whatever theme or picture you want as the background. It is slightly different for other windows system, but you should start with right-clicking on a blank part of the screen..
Jan 30, 2012 | Samsung N150 (36725723009) Netbook
How to preform pc restore for windows 7 in dell laptop?
As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
Press the <Down Arrow> on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press <Enter>.
Specify the language settings that you want, and then click Next.
Log in as a user who has administrative credentials, and then click OK.
Click Dell Factory Image Restore.
In the Dell Factory Image Restore window, click Next.
Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
Click Next.
The computer is restored to the default factory configuration.
When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
Jun 12, 2010 | Dell Inspiron 1501 Notebook
Image not seen on screen...only a blue background
go into the settings menu and select the computer input.
Jul 17, 2009 | Sanyo PLC XU35 Multimedia Projector
Gigabeat S Series firmware restore
I just solved the same problem yesterday. When you download the firmware, save it to yur desktop and burn a CD because the gigabeat won't get it unless there is an actual CD in the rom.
Now, connect the gigabeat to the computer and let the firmware install. The unit will automatically restart twice. Here's the tricky part. You have to hold down the start button on the device until you see the start screen. (It took awhile for me to figure that out!)
After I saw the start screen, I saw that all my files were there! YAY
Jan 10, 2009 | Toshiba gigabeat MES60VK Digital Media...
Help!!!
So, what happened when you connected the thing to sync with a PC and rightclicked on the tool-tray item for the Gigabeat?  Maybe you got a menu about Upload Portable Media Center?  If not, go into applications and see if the gigabeat stuff doesn't happen to contain the bespoken user manual.  Open it...read it....  Usually there's a little button-sequence to prepare the player and another to restore the Portable Media Center program.  Happy discovering.
Jun 16, 2008 | Toshiba gigabeat MES60VK Digital Media...
Toshiba Gigabeat S30 MP3 Player Logo
137 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
