I do not have orginal remote for the RCA J25435 TV and would like to change input to play Game Cube and XBox. How do I change the input to show the device plugged into the front of the TV?
There is no source button. The front of the tv only has Menu,volume, channel, and power. When u manually go thru the channels the AUX does not come up. I have this tv and have not found a solution to this problem either.
Posted on Aug 29, 2013
SOURCE: How do I change to the front inputs to play video games w/o the remote?
There should be a button on the frame of the TV that say's input. or Source, Press that button until you have the game showing on the screen. Make sure the game is turned on before you start changing inputs..
Posted on Oct 31, 2008
Benimur
  • 6966 Answers
SOURCE: cant get dvd to work
Hi, Do a hard reset. Unplug the unit for a couple of hours. Most current models will reset to default condition this way. If this does not correct the fault, pls post back with the brand/model/version of your unit. Good luck and kind regards.
Posted on Sep 22, 2007
scottyfixit
  • 186 Answers
SOURCE: input source change on remote for tv
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Posted on Apr 26, 2008
  • 476 Answers
SOURCE: cannot change input source for tv
i would try the abvious first, unplugg the tv from the ac outlet and wait for a few seconds then try turning tv on see if the problem is solved, if not it might be that the key board panel needs replacing.
Posted on Aug 02, 2009
  • 5 Answers
SOURCE: how do you switch to aux on a rca tv
Sometimes the "Aux" input "channel" is found BEFORE Channel 2 (between your last channel and your first). Other times, you have to use your remote, go to Menu and setup. It varies with almost every TV, so you may have to try all approaches.
Posted on Aug 18, 2009
I have a rca model j25435 tv and we have the remote but it won't go to certain channels and we can't get the dvd player to work with it either
I found this online-
You are right this is a hotel TV. When they sell those they usually bundle the "master" remote with one of the TV and the remaining TV get the "guest" remote.
With the Master remote you have an easy access to all the option you want. Here is a place to order it:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=J25435%20MASTER&brand_pn=RCA_J25435%20MASTER&mode=large&uuid=12440896969550
May 26, 2014 | Televison & Video
Rca remote won't change different inputs
1) test the batteries for dead
2) clean the contacts batteries
3)tight the springs contacts batteries with long pliers for better contacts
4) open the remote control clean the KEYPADS for dirty, oxide, corrosion and fix itl
5) try it
6) if doesnot work,you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | RCA Universal Remote Control
I have a RCA TV 2002. i CANNOT GET THE NINETO GAME CUBE TO PLAY. HOW CAN I GET TO PLAY?
You're not very clear about why you cannot get the GameCube to play, but if I may assume, it sounds as though your TV does not have the necessary input to get the game cube plugged into it.
If this is correct, you can find an RF Adapter which will work on Any TV with a coaxial (cable) input. If your TV doesn't have the red, yellow, white inputs, this will work for your gamecube and your TV:
http://store.richspsxparts.com/garfadc.html
Jun 16, 2011 | Nintendo GameCube Console
I can not figure out how to put my Toshiba M454 to Line 1 to play my Gamecube.
  1. Run your AV cords from your Game Cube to your VCR input in the back.
  2. Now run the AV inputs from the VCR (outputs) to your TV (inputs)
  3. Now you press "input" on the remote on your VCR to make the VCR play your input thr Game Cube is hooked up to.
  4. Now you set your TV to what ever input you hooked your AV cable from your VCR to.
  5. Turn the Game Cube on and play.
Regards, Tony
May 04, 2011 | Toshiba M454 VCR
My xbox 360 is showing in black an white regardless of the wire i use
Most likely it is your tv that is showing in black and white. Teste the inputs on the tv and try changing the xbox to a different input setting...e.g. coax, rca, component, etc. Please rate this solution for me.
Jan 22, 2011 | Microsoft Xbox 360 Console
My Xbox360 will not play Orginal XBox 360 Game Disc
hack cheat repair and unlock xbox 360 yourself in less than 1 hour
http://3redlight.tk
May 04, 2010 | Buck Legendary: The Box for Xbox 360
How to put input on a samsung plasma? I have a samsung plasma and I am trying to connect an Xbox, can someone help?
you will have to use component cables with rca's
from xbox plug to rca to plasmas component input
use your plasmas remote to locate a channel to tune int channel o your xbox,when you turn on xbox the start screen should show,dont need a disk for tuning just playing
go forth and have fun .
Cheers MISTERDJ
Apr 11, 2010 | Samsung (TN-RBNG10) TV Input
Can't change input to play Xbox without clicker. With tv clicker I could access channel 00, which allowed me to play xbox. now the clicker is broke and I can't access channel 00. can i do this through...
The only way is with the remote. Try to find a GE or RCA universal remote. These remotes are designed around GE and RCA tv's and generally don't have to be programmed. (GE and RCA are both THOMSON made sets). Thanks
Oct 13, 2009 | GE 31GT660 TV
Cant get vidiogame channel
look on the remote for av/tv or input select av input
May 02, 2009 | RCA F27641BC 27" TV
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Nov 09, 2008 | RCA F35673MB 35" TV
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
