Question about Intermatic Programmable 24 Wall Switch Timer Ej351c
I have programmed this timer many times and never had a problem untril recently. It comes on and goes off at times other than what I programmed it to do. Is it time to replace it?
    Problem Solver:
  • 4 Answers
You probably switched to a CFL (compact flourscent light bulb). This switch only works with incandescent bulbs. Try the Intermatic ST01C switch. The ST01C works with CFL's and LED's. I just ordered one from WestsideWholesale.com They had the best price.
Posted on Sep 21, 2010
Programming Utilitech E210007 timer
This advice<<<<<< Press the "PROG" or "Program" button. Press the "Day," "Hours" and "Minutes" buttons to set a specific day and time at which you want the timer to power on that device.>>>>
came from:
http://www.ehow.com/how_7874878_utilitech-digital-programmable-timer-instructions.htm
Dec 15, 2013 | Hardware & Accessories
Timer programming help
Maybe the sprinkler head is not advancing.
May 22, 2013 | Orbit Hardware & Accessories
Friend left RCT100 timer programmed, it comes on the time programmed, but it goes off much earlier than it is supposed to. How can I correct this?
Most digital timer problems can be solved by resetting timer.
Open following link for possible instruction manual with troubleshoot steps
http://waterheatertimer.org/UPM-timers-and-manuals.html#Garrison
Check the following:
Program disable feature is not enabled.
Check 2 different sets of batteries: 1 set AA for transmitter, and 1 set button-cell batteries on back of timer
Choose between 4 different functions: programmable, photocell, countdown, or random
Using programmable mode: make sure there are no programming conflicts
Jul 20, 2011 | UPM Remote Control Timer Set
Timer goes off ok. but does not come on at determined time.
1) Replace CR2 battery
2) Reset timer is suggested as last step troubleshoot
Reset instructions and ez programming and battery information on following link:
http://waterheatertimer.org/ST01C-program.html
if functionality will nto restore, then buy another timer.
For dawn-dusk, replace timer with Aube, Utilitec, or Sylvania
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
1000w athena glass panel heater, how to set timer/program?
Recently bought the Athena glass panel heater from B&Q but there were no instructions. Easy enough to set time but how do you set the timer for coming on in the morning and then again in the evening?
Dec 07, 2010 | Heating & Cooling
I also am having trouble with this timer. I've got the program set for when I want it to go on but can't figure out how to put in the time I want it to stop. I don't understand where the countdown timer...
ETW350 is programmable timer that offers 3 different timer
functions: Program, countdown and random.
Timer has 20 different settings.
UPM site is not available recently, but UPM timers are still being sold.
Operation manual is not very clear how to program ON and OFF times.
http://waterheatertimer.org/pdf/UPM-etw350.pdf
That being said, usually with programmable timers, you program ON time. And then program OFF time.
I do not own this timer so I can't test ETW350 like I've tested other timers.
I think the way this timer works, is program1 is ON.
And program2 is OFF.
Again, manual is not CLEAR about ON and OFF times.
Following instructions assume timer is wired correctly, timer is set for current time, and you want to set 'timer' function and not 'random' function.
Here's how to set program1.
Press arrow buttons until 1 shows in display. This is program1.
Press Set button.
Select day for program1 ON using arrow keys
Press Set button.
Select hour for program1 ON using arrow keys.
Press Set button.
Select minute for program1 ON using arrow keys.
Press Set button.
Use arrow keys until 2 appears on display. This is program2.
I believe program2 is for OFF times.
Set program2 using same steps above.
Be careful to match ON and OFF days ... for example ON 7pm Monday and OFF 9pm Friday will keep lights on from Mon through FRI.
Conflicts in programming will cause timer not to work. For example program1 ON 7pm Monday, program2 OFF 9pm Monday ... but programs3-4 say opposite times.
Make a schedule of program times before starting to avoid conflicts.
Try steps above and test fire that timer, and then add a comment.
Nov 24, 2010 | UPM Programmable Wall Switch Timer
I have a EC4000 electronic digital timer. The problem is when the timer hits a preset time to turn the boiler on , the boiler will not turn on, but when I hit the manual override button on the timer the...
Paragon EC4000series are programmable timers
EC4000/120 for 120V
EC4000/277 for 208-277V
Is this a new installation?
Or was timer working fine until recently?
1) With digital programmable timers like EC4000, if there is conflict in programming, or missed program, then timer might skip the program.
For example if program1 says ON at 7 and OFF at 8, and program2 says the opposite.
2) If wiring is reversed, then the manual override will work but clock will not operate, and the timer will not function.
a) for 120V timer:
-120V black wire from breaker goes to terminal2
-120V white wire from breaker to terminal1
-jumper wire from terminal2 to terminal3
-Load black wire to terminal4
-Load white wire to terminal1
b) for 240V timer
-240V Hots from breaker go to terminal1 and 2
-Load wires connect to terminal4 and terminal1
Below is link to EC4000 instruction manual
http://waterheatertimer.org/pdf/Paragon-EC4000-program.pdf
Troubleshooting steps say to review set-points.
Solutions:
Checking wiring as described above
Check programming.
Reset timer and re-program set times.
If you need more help, add a comment at bottom
Oct 26, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Radio Shack 63-891 Electronic Timer: Seems I'm able to program the time at which timer turns the power on. How do you program the time at which the power goes OFF? Thanks for any help you can...
The timer has 8 programs that will run. This will give 4 ON/OFF cycles if all are used. Set program 1 as the ON time, program 2 as the OFF time. Use each odd program # as the ON time and each even program # as the off time. Do this in PROGRAM mode then switch to RUN with the upper switch set to TIMER to actually start the program running. ON will turn it ON during the OFF cycle and OFF will turn it OFF during the ON cycle.
Sep 04, 2010 | Hardware & Accessories
Intermatic Programmable 24 Wall Switch Timer Ej351c Logo
121 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
