Question about Keurig B60 Coffee Maker
When I try to make a cup of coffee the water dispenses back into the resevoir tank rather then through the filter and into the cup.
  • Keurig Master
  • 1,711 Answers
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig, you have something you can do at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 20, 2010
  • espressonist
    espressonist Aug 20, 2010
    http://www.fixya.com/support/r5543433-ke...
    Good luck
    Good luck
Water drips back into resevoir, only filling 1/4 cup. I have de-scaled, cleaned the holes, reset the resevoir, use only distilled water
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 08, 2011 | Keurig B100 Coffee Maker
Very little water comes out while brewing and its brand new
Could be the exit valve on the k-cup holder is clogged.had same prob and fixed in 2 mins.Take out k-cup holder as if you were going to brew your own grinds.It will twist off into two pcs.Take the top pce and get a paper clip and stick end of paper clip into valve from the bottom and wiggle a little then run under water to clean out.reassemble and you should be brewing coffee again.Good luck
Apr 07, 2010 | Keurig Platinum B70 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
Does not dispense water unless you pinch vent in water tank.
If your Keurig is putting water out the vent and back into the reservoir. Open the front, using a flashlight and a toothpick, clean the coffee grinds out of the little hole in the needle that pierces the K cup. When it becomes clogged with grinds the water either has to come out the vent or the coffee maker will burn out. It is a safety mechanism.
Feb 28, 2009 | Keurig Elite B40 Coffee Maker
BKC600XL Stainless Steel Coffee Just purchased...during the priming no water entered the machime and it is stuck on "heating". I think i had the water filter on wrong. I fixed that but now need to reset to...
After trying just about everything (I had the exact problem you describe) I finally got it working.
In my case the reason why it was stuck on heating is because no water was getting into the heating tank. I removed the charcoal filter, unplugged my machine and plugged it back in again. I then saw the water resevoir level drop and knew that water was now being heated.
I made a couple of cups of coffee then put the charcoal filter back in and now everything is working great.
I hope this helps your problem.
D
Dec 12, 2008 | Breville BKC600XL Coffee Maker
Keurig B60 Coffee Maker Logo
954 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
